Post by FrankenMech on Sept 5, 2014 18:56:16 GMT -5
For ice why couldn't a person use an old worn set of tires and run short sheet metal screws, not self drillers, from the inside? Fill the tire with slime to ~seal/slow the leaks.
Note: I have used hex head sheet metal screws in the lugs of my boots for traction in mud and snow for 30+ years. I also relieve the lugs to make the grooves wider and more open to release the mud and snow better. S-hook type fixture chain works great on regular shoes and boots for traction.
Post by walleye1963 on Sept 5, 2014 19:20:30 GMT -5
That's what's I'm talking about the ocegon screws they work best they will come out but hell when your wot there just going to hit the guy behind you if your scoot is turn right hell I don't no all I do no is I,d love to be in on the line when the flag go,s down and ride like I should it yeha
Post by moofus02 on Sept 6, 2014 7:29:00 GMT -5
Someone on here gave me a link for actual tire studs for motorcycles. I'd have to search for it. They make scooter tires in a winter tread just like car tires. Really aggressive with all the cuts and sipes. Most of those are designed for studs. Leave the center contact patch bare and stud the outside of the tire so as you lean a little the studs start biting in. Didn't want to do that to my good bike but now that i have a couple that aren't so pretty i might do up a set of tires on spare rims so i can slap them on when the snow starts. We used to run hex head sheet metal screws with a raised edge in the knobbies of the dirt bikes and atv's
Post by kkzxxx on Sept 6, 2014 14:29:48 GMT -5
heres a very inspirational(and scary) video for you
I rode in snow and on streets last winter, but streets were mostly clean so there was no need for studs, but this year its gona be different.My new scooter has 16 and 14 inch wheels so it should bite the snow better but the 2t engine needs more traction, so im gona buy some knobbys and put some screws in, i sure hope it works tho...
Post by Nokatay on Sept 6, 2014 16:09:21 GMT -5
Adda side car and you can ride all year long.
Post by walleye1963 on Sept 6, 2014 19:11:41 GMT -5
Were do I send flowers he,s a dead man i,d go at speeds on a lake he,s just crazy
Post by scooterpimp on Sept 6, 2014 19:32:32 GMT -5
Nice to have a 3 wheeled scoot on snowy road.
Post by FrankenMech on Sept 7, 2014 9:53:19 GMT -5
I rode my R-trike last winter but not like THAT! I just went out when the streets were clear. Helmet fogging was a major problem.
Post by niz76 on Sept 7, 2014 11:59:27 GMT -5
I rode all winter last year, but all I got to show for it was a sunburned head.
Post by moofus02 on Sept 7, 2014 12:59:10 GMT -5
I road in the snow a few times and the stock duel sport tires did an OK job on anything but ice
