Post by 'O'Verse on Sept 20, 2014 2:28:09 GMT -5
But does the oil enricher hose have to be used? I have the vacuum hose from the petcock running to one of the ports on the intake. Can't I tie the oil enricher hose of and just cap the other intake port. 24 mm Oko carb. 90cc minarelli engine.Doesn't my engine already mix the oil and gas together?
Post by 90GTVert on Sept 20, 2014 10:03:04 GMT -5
Right now your scoot should have an oil injection system that handles adding oil into the incoming charge for you. If you switch to pre-mixing then yes you can cap off the intake and do away with the oil injection system, but you have to add oil every time you add gas and at a certain ratio. Some take a little hose and loop it from inlet to outlet on the pump, but I prefer to get all of the injection stuff out of there. Here's some more info on pre-mix vs injection. 49ccscoot.proboards.com/thread/564/remove-oil-injection-system
Post by 'O'Verse on Sept 20, 2014 13:13:06 GMT -5
Very helpful thank you 90tvert.
