Post by jecklen16 on Sept 13, 2014 11:07:01 GMT -5
Okay, so I don't know what this gear is called, but it wont turn. My starter works fine but this gear doesn't move at all so it's not spinning spinning the crank. Any idea how to 1. get it off and 2. fix it?
Post by jecklen16 on Sept 13, 2014 16:46:39 GMT -5
Anyone have any ideas?
Post by katastroff on Sept 13, 2014 16:59:44 GMT -5
Hi and welcome. That gear is not suppose to turn on her own. Your kickstarter makes it turn when you ingnite your engine. If you want to take it out, you need a puller.
Post by jecklen16 on Sept 13, 2014 17:27:50 GMT -5
My electric starter is connected to this gear though, so what exactly is my electric gear supposed to be turning?
Post by katastroff on Sept 13, 2014 18:11:42 GMT -5
Post by jecklen16 on Sept 14, 2014 12:59:30 GMT -5
Okay so I went to that link (thank you for that info btw), my starter clutch and gear are completely rusted over and the gear itself was stuck on the race until I pried it off after an hour or so. The clutch is bad too. I counted the teeth and found that the inside of the clutch is 15 teeth and the outside of the starter gear is 62 teeth. The closest clutch assembly I can even find to mine is this one www.scooterpartsexpress.com/starter-clutch-assembly-4950cc-2t-1pe40qmb-1e40qmb-jog-minarelli-typeand that says 15 inside 68 outside... so I'm kind of at a loss as where to go. Will that work? Is that even the right size?
