Post by jareeb on Sept 14, 2014 12:53:53 GMT -5
i cant find an actual replacement piston from stage6 but work another brand piston work? if so what one is good? also its an o-ringed head but i could always use a different head with any 47mm gaskets. im not sure how to figure out what model jug this is but its an air cooled, cast iron, black jug.
Post by 2TDave on Sept 14, 2014 13:18:53 GMT -5
Scootertuningca.com sells the pistons and gaskets. I've used a Hoca head gasket(o-ring) from partsforscooters.com. If it's Stage6 iron should be the Streetrace. Measure the bore. There are 47 and 47.6 bores.
Post by jareeb on Sept 14, 2014 13:22:47 GMT -5
it came out to about 46.8* i dont remember. so it is a 47mm
Post by jareeb on Sept 14, 2014 13:30:11 GMT -5
Post by 2TDave on Sept 14, 2014 13:42:15 GMT -5
Hmm, maybe I was wrong.
Post by jareeb on Sept 14, 2014 14:04:29 GMT -5
so should i go with the hoca stuff or something else?
Post by 2TDave on Sept 14, 2014 14:11:12 GMT -5
I'd verify the size of your cylinder. I recall there being two different bore sizes.
Post by jareeb on Sept 14, 2014 14:20:04 GMT -5
i did measure it last night and it was close to 47mm like just under.
Post by Corrosion on Sept 14, 2014 15:01:56 GMT -5
Post by 2TDave on Sept 14, 2014 15:48:26 GMT -5
Scootertuningca is in Canada so the shipping is the same as in the states. If they have to get them from across the pond you only pay shipping from Canada.
Post by jareeb on Sept 14, 2014 22:32:29 GMT -5
10mm pin. thanks guys.
anyone hear anything bad about Motoforce Evolution Racing 10mm crankshafts? the engine is gona get built with a crank after TNG
Post by 2TDave on Sept 15, 2014 5:14:46 GMT -5
Haven't heard anything bad but if you plan on doing a full motor build why not go 12 mm pin? Stage6 according to a website description doesn't put their name on the Streetrace cylinder and they stamp it 49ccm and it's black.
Post by usmcdoc on Sept 15, 2014 7:23:21 GMT -5
Post by jareeb on Sept 15, 2014 10:39:05 GMT -5
my jug does say its a 49. im not going with a full race build just want to handle extra rpms.
Post by 2TDave on Sept 15, 2014 10:48:38 GMT -5
The S6 Streetrace is a sport kit not a race kit.
