Post by jareeb on Sept 15, 2014 13:34:07 GMT -5
Post by 90GTVert on Sept 20, 2014 7:21:05 GMT -5
Looks good. Should be the same jets as a 19mm PHBG (5mm DellOrto) I'd guess.
Post by jareeb on Sept 20, 2014 9:26:45 GMT -5
where do you get jetting kits from?
Post by 90GTVert on Sept 20, 2014 9:52:47 GMT -5
Post by Corrosion on Sept 20, 2014 10:21:29 GMT -5
May want to consider a Clone Dellorto Racing. Tuning options are near endless, and easy to work on. You would need a W-7 needle & a 40 slide. And 5mm jets in the 90's range with the clone's I have used, But there still a bargin.
FYI. I got my last one for a $30.00 bid.
+1 for treatland for Dell, parts!
Post by jareeb on Sept 20, 2014 10:40:27 GMT -5
i already order the carb. if its hard to tune then ill get a dell. i just am running out of time for ordering parts.
Post by Corrosion on Sept 20, 2014 11:04:19 GMT -5
They come from China, so 3-4 weeks normal shipping times, sometimes longer.
Post by jareeb on Sept 20, 2014 11:25:24 GMT -5
this ones in CA. but ik the dells are
