Post by Kristijan on Sept 15, 2014 15:15:11 GMT -5
i have znen 50QT-A15 scooter with upgraded 80cc engine..everything is stock except variator..i have malossi multivar kit with 5.1gr rollers..now the thing is that i don't changed the white contra spring from malossi (i leaved the stock one with the stock clutch) .. any suggestions to try this: change the white contra spring with stock one, and change the white clutch springs with stock one and leave the variator with 5.1gr rollers ?? thanks everyone
Post by katastroff on Sept 15, 2014 16:17:40 GMT -5
Hi and welcome!!!!
Those springs came with the kit as a whole. You should surely get better performance from your scooter if you install them.
Post by scooterpimp on Sept 15, 2014 18:48:58 GMT -5
Post by Kristijan on Sept 16, 2014 5:02:44 GMT -5
yeah they came with the kit..thank you anyway, i'll try and i will post the results..thanks again man
