Post by lordaudie on Sept 27, 2014 12:35:18 GMT -5
Post by jhobe6678 on Sept 27, 2014 12:52:26 GMT -5
Hah, you bought the same fuel line I did, the blue 1/4" ID. Hmm. Do you have a Manual? What model/year is it? I'm assuming it's a 4 stroke so this post may get moved to that forum, just FYI. The pictures def help though, good job on that and welcome to the forum!
Post by lordaudie on Sept 27, 2014 13:04:17 GMT -5
Thank you. No I don't think i have the manual. I can check online. This is another pic of the disconnected hose. This one shows where is coming from. i.minus.com/jbg8TAr85oJQBZ.JPG
Post by jhobe6678 on Sept 27, 2014 13:11:05 GMT -5
I couldn't say exactly. I'm not familiar with the 4strokes yet, I'm barely familiar with 2 stroke. But I know someone is bound to have that answer for you and maybe some more insight as to what to look for! Hang in there.
Post by niz76 on Sept 27, 2014 13:20:55 GMT -5
I don't know too much about 4T's either, but I've had starting and running issues due to low compression before. Luckily all my scoot needed was the cylinder head nuts to be tightened and presto! 90psi is about the minimum for 2t's- don't know about 4t though... lots of 4t guys here. Someone will be along to help!
Post by lordaudie on Sept 27, 2014 13:45:52 GMT -5
What do you mean by low compression?
Post by katastroff on Sept 27, 2014 14:17:26 GMT -5
The disconnected electric plug probably goes to your auto-enricher on your carburator. The unpluged hose is part of the anti pollution gizmo and goes at the end of the U shape chromed pipe that come out of the valve cover.
Post by katastroff on Sept 27, 2014 14:21:20 GMT -5
Hose goes here:
Post by katastroff on Sept 27, 2014 14:28:49 GMT -5
Electrical plug should plug in the plug from the carb:
Post by lordaudie on Sept 27, 2014 14:58:00 GMT -5
Post by Elektrey on Sept 27, 2014 14:58:19 GMT -5
Unless you can give some specific scenario that would hint to why it would not start, I would say troubleshoot it in order. (check for spark, compression, fuel, etc. untill you get to something that needs fixing)
Post by lordaudie on Sept 27, 2014 15:15:42 GMT -5
It has spark.
Sometimes it would start but then it idles down.
Checked the fuel lines and I believe that is getting fuel.
One thing that I noticed is that when it turned on the hose was taking air in.
Post by iwannascoot on Sept 27, 2014 15:22:40 GMT -5
My Taotao has the same plug that appears to be a spare. There is nothing plugged to it. The wires are green and black/white. I don't think that is a issue for you. The hose looks like it should go to a nipple on the intake manifold. Does it come from the same place as the hose on the "u shaped chrome thing?" If it does then you have a vacuum leak that would cause your engine to run very poorly if at all. Billy
Post by katastroff on Sept 27, 2014 15:23:51 GMT -5
All about that hose that worries you so much:
Post by katastroff on Sept 27, 2014 15:25:57 GMT -5
For the electric plug: Look for its mate somewhere on the bike. On mine, there use to have 2 plugs of that size. one was for the carb auto"choke", the other went to the magneto.
