Post by Elektrey on Sept 29, 2014 13:23:50 GMT -5
Well I am still adjusting air to fuel mixture at WOT but when I had it right before, the idle would never adjust correctly.
I would adjust idle to where it idled highest RPMs but it would give me a lean hang at 4-5k rpms.
When I turned it to where the hang was gone it was very rich and off the line acceleration was slower and it idled very low, almost stalling.
Is it possible to have a rich hang?
I am going to look at idle again once I get the overall a/f mixture right, so it may not do it, but it made me curious.
Post by Jwhood on Sept 29, 2014 14:19:30 GMT -5
Reeds could be bent,the factory reeds are metal or you could have an exhaust leak or a intake leak!!!
Post by Elektrey on Sept 29, 2014 17:00:29 GMT -5
I've thought about leaks but it seems unlikely because nothing has changed with the scoot. It was idling fine at one point. What would cause reeds to bend?
Post by Jwhood on Sept 29, 2014 21:34:05 GMT -5
They open in close all the time when you give it throttle they open up and let fuel into cylinder,eventually they will snap,causing you major engine damage,get you some carbon fiber reeds,the stock thickness is 0.30mm and they are 3 petal reeds
