Post by iwiketuddlz on Oct 4, 2014 19:24:59 GMT -5
What does it mean it u can look in my exhaust port and see 2mm of piston at bdc?
Post by 190mech on Oct 5, 2014 3:47:18 GMT -5
Wrong cylinder!
Post by iwiketuddlz on Oct 5, 2014 5:36:46 GMT -5
Mmm i knew something was off,it has power but it Never gets " on the pipe". Wonder what size cylinder I need?
Post by iwiketuddlz on Oct 5, 2014 5:42:15 GMT -5
I'm going to teat it back down today and do some measuring to see what I need.
Post by 2TDave on Oct 5, 2014 5:54:02 GMT -5
What's your setup?
Post by iwiketuddlz on Oct 5, 2014 6:10:54 GMT -5
The hoca 70cc kit with one base gasket, stock crank I assume. And actually I can see the edge of the top ring at bdc so its more like 3mm exposed
Post by iwiketuddlz on Oct 5, 2014 6:25:17 GMT -5
Oh and in running the tecnigas exhaust with blue silencer
Post by iwiketuddlz on Oct 5, 2014 6:26:06 GMT -5
Sry 19mm dellorto carb with stock airbox
Post by iwiketuddlz on Oct 5, 2014 7:16:40 GMT -5
I'm assuming this is why it seems to be getting weaker each day ,I have put over 400miles on it lik it is now and it certainly don't have the power it had at first and It has never ,hit the pipe, I kinda like thought that was odd as well
Post by iwiketuddlz on Oct 5, 2014 8:57:48 GMT -5
The rod has ....yp 4O.... stamped on it. Is that stock? Also the old jug and new measure the same height 64mm. I just don't get it ,to mak my piston flush with th xhaus port I will need 3mm of spacing ,but that would kill my compression.
Post by iwiketuddlz on Oct 5, 2014 10:56:58 GMT -5
I definitely have to buy a new crank as the big end has a gap of 1mm, I eventually want to go to a 54mm bore but iI want to buy a crank now to run with h the kit I have any suggestions? Sorce/ price for a good crank?
Post by 190mech on Oct 5, 2014 19:32:46 GMT -5
Have you checked the squish or piston to cylinder deck height yet??
Post by iwiketuddlz on Oct 6, 2014 5:15:20 GMT -5
No I haven't checked squish and the deck hight is 1.3 mm or so it looks good
Post by iwiketuddlz on Oct 6, 2014 5:17:44 GMT -5
Compression is around 170psi is that good? And it does get on the pipe its just really weak when it hits,not sure why,maybe my exhaust? Tecnigas
Post by 2TDave on Oct 6, 2014 5:55:06 GMT -5
Compression is good.
