Post by iwiketuddlz on Oct 7, 2014 16:22:36 GMT -5
What size are my crank seals? Anyone know off hand?
Post by 2TDave on Oct 7, 2014 16:35:08 GMT -5
The spline size is where the variator slides on and the taper is where the flywheel slides on. The Doppler is for the Zuma. Can you measure you crank shaft spline or the opening in the variator that slides on the shaft?
Post by iwiketuddlz on Oct 7, 2014 16:54:58 GMT -5
Yea mine is the same as yours,its 16mm variator side dunno bout flywheel side I'm waiting on racing planet for my tool to remove it. So....I orderd wrong crank huh?
Post by 2TDave on Oct 7, 2014 18:16:22 GMT -5
Yea. They only offer a Stage6 hpc for those. You'd have to get a small spline flywheel, vari, fixed pulley, kick start gear and starter clutch. I went to a OR at the same time I did my crank so all I really needed was the flywheel and kick gear. No electric start with OR.
Post by iwiketuddlz on Oct 7, 2014 18:28:56 GMT -5
OK should I keep it or just get the other stuff to go with it?
Post by iwiketuddlz on Oct 7, 2014 18:41:40 GMT -5
Yea IMA just keep it ,my local scoot shop has a bunch of small end stuff I can get fixed pully and flywheel from there pretty cheap,just have to hit up partsforscoots for a small backplate for my hoca vary. Dang that will slow me down as I'm out of funds lol
Post by niz76 on Oct 7, 2014 21:04:04 GMT -5
Yea IMA just keep it ,my local scoot shop has a bunch of small end stuff I can get fixed pully and flywheel from there pretty cheap,just have to hit up partsforscoots for a small backplate for my hoca vary. Dang that will slow me down as I'm out of funds lol I have an extra small splined back plate for a Hoca vari. My small spline scoot got stolen and the next scoot I bought was a large spline. Brent hooked me up with a large spline Hoca backplate for the cost of shipping and i'm willing to do the same and pass it on. Depending on where u live should be like $6-$7. PM me if interested.
Post by iwiketuddlz on Oct 7, 2014 21:12:44 GMT -5
Sweet dude ,yea I def want it, it will be one less thing slowing me down installing my crank which should be here Friday
Post by iwiketuddlz on Oct 7, 2014 21:16:59 GMT -5
Im going to stop by that shop after work tomorrow and price the flywheel ,fixed plate,starter plate,kick gear and I think that's it thanks
Post by 2TDave on Oct 8, 2014 5:24:58 GMT -5
You'll need the small spline variator boss/ hub if you plan on keeping your variator. Do you have a hoca vari now?
Post by iwiketuddlz on Oct 8, 2014 5:27:23 GMT -5
Yea I just need the small spline backplate for my hoca I have now,witch niz is going to sell me ,I just hope the other parts aren't going to cost me much otherwise iI will return the crank
Post by iwiketuddlz on Oct 8, 2014 5:29:16 GMT -5
Thanks Dave for the help, I should have the crank in by the weekend I hope it makes a diff. In performance
Post by 2TDave on Oct 8, 2014 5:54:34 GMT -5
You will need a small spline boss. This is the part that slides on the shaft between the variator and fixed pulley.
Post by iwiketuddlz on Oct 8, 2014 6:32:05 GMT -5
Well nvm I can't put it in until racintplanet send my flywheel tool sigh,I'm betting it won't work with the small taper flywheel? I got a 27mm flywheel tool.
Post by iwiketuddlz on Oct 8, 2014 6:32:58 GMT -5
Damn your right Dave ,shit I may as well just buy a new vary.....sigh
