Post by 2TDave on Oct 8, 2014 6:41:41 GMT -5
See what Niz used. Maybe a stock small spline boss will work.
Post by iwiketuddlz on Oct 8, 2014 7:39:45 GMT -5
Yea I ask if he had a boss, no sure what will work yet
Post by iwiketuddlz on Oct 8, 2014 7:42:04 GMT -5
Also Dave was the or kit worth it? And it Ibuy an OR vqriator wwill I work with the stock torque driver/rear pully! Do I buy a longr belt?
Post by 2TDave on Oct 8, 2014 7:50:20 GMT -5
I like the OR but it's expensive. Gary at Gforce can get you an OR set up for the large spline crank if you decide to do it later. I'm not sure about using the variator w/o the td. The OR does use different belts for more travel.
Post by iwiketuddlz on Oct 8, 2014 9:18:04 GMT -5
This seems to be a bit more work than I expected.... But oh well it makes it fun,Im addicted to theses scoot engines ,I reallylike the 2t sstuff..... Awesome .....
Post by niz76 on Oct 8, 2014 12:29:27 GMT -5
Not sure what I was thinking when I said the boss I have is restricted- that one is for stock vari. I do have the small spline Hoca boss! BTW the backplate doesn't have the plastic guides as I used them elsewhere....
Post by niz76 on Oct 8, 2014 14:10:05 GMT -5
Pkg. is shipped and on it's way! PM sent.
Post by iwiketuddlz on Oct 8, 2014 16:49:07 GMT -5
That's OK I have new guides,and thanks niz ,paid In full.
Post by iwiketuddlz on Oct 8, 2014 16:50:55 GMT -5
Man ST. Has a sweet deal on Athena 43mm crank and matching 80cc kit I'm thinking of buying that instead ,it will be nice
Post by niz76 on Oct 8, 2014 16:51:06 GMT -5
Awesome. Should be there Friday.
Post by iwiketuddlz on Oct 11, 2014 4:49:01 GMT -5
I have everything to do the crank swap just need a woodruff key,will mine on thelarge crank work on rthe small one?
Post by 2TDave on Oct 11, 2014 5:17:06 GMT -5
Yes. You can also modify one that you can buy. Brent has the size and mod in the tech section. It may be in the thread with seal and bearing sizes.
Post by iwiketuddlz on Oct 11, 2014 7:24:24 GMT -5
Sweet thanks dave
Post by iwiketuddlz on Oct 11, 2014 7:25:27 GMT -5
How about the case gasket can I use rtv sealent!
Post by iwiketuddlz on Oct 11, 2014 7:27:33 GMT -5
I'm certainly going to modify my cases and do some trench work like I read about in the tech a section
