Post by ahscoots on Oct 14, 2014 21:29:25 GMT -5
Bought 2 new tao taos and the red one will not pull itself up hills adjusted valves and it didn't help. What do i do? It literally has to be pushed up hills but runs decent on flat ground
Post by Deleted on Oct 15, 2014 1:51:00 GMT -5
torque sheave spring is too light or the rollers are wayyyy to heavy...or both
Post by Clank on Oct 15, 2014 2:15:54 GMT -5
Something is sticking or broken in your CVT IMO. :welcome2:
:popcorn:
Post by stevec on Oct 15, 2014 5:15:30 GMT -5
sounds like a CVT issue, i had a red GT5-50 that wouldn't take off on hills, i replaced the clutch and belt and it helped, used 5g rollers and it was fine after that.
Post by stepthrutuner on Oct 15, 2014 5:58:03 GMT -5
If the comp. is like 120 psi or better and the rotor/reluctor orientation is proper then tranny is not reacting properly. You should be able to sense this from engine speed comparations between the poor running scoot and the proper running one.
Post by ahscoots on Oct 15, 2014 18:39:13 GMT -5
How do i check cvt without removing
Post by katastroff on Oct 15, 2014 18:43:40 GMT -5
How do i check cvt without removing You dont.
You need to open it up to check the weight of your rollers, the strenght of your contra spring and the general state of your belt.
Post by ahscoots on Oct 15, 2014 19:04:29 GMT -5
How do i check contra spring rate??
Post by katastroff on Oct 15, 2014 19:45:33 GMT -5
A stock contra is a little bit softer then an aftermaket soft one.
Post by ahscoots on Oct 15, 2014 21:47:22 GMT -5
Do i need an impact gun to remove that nut on the clutches?
Post by niz76 on Oct 15, 2014 22:20:32 GMT -5
Do i need an impact gun to remove that nut on the clutches? The short answer is "yes". However, I have had to resort to other measures as my impact frequently has a hard time breaking the initial factory torque on the clutch nut and the variator nut. I've tried a few different things to hold the clutch bell while breaking the nut loose from a strap wrench to (unsuccessfully) fabricating a tool to hold it. Recently I've been using a huge 'C' clamp to clamp the bell and break the nut loose.... Have you checked the weight of the rollers in the scoots? Heavy roller weights can mimic the effect of a soft contra spring... Although they may be two identical new scoots, the Chinese have a reputation for being inconsistent with parts.
Post by ahscoots on Oct 16, 2014 5:14:02 GMT -5
I will check tonight. I have to remove cluth though right?
Post by ahscoots on Oct 16, 2014 16:38:05 GMT -5
I just weighed my roller weights they dont seem to have any flat spots and they are all 5 gram weights my clutch pads look good and so does belt. So what can it be?
Post by katastroff on Oct 16, 2014 16:49:34 GMT -5
If you got good compression, it would be your that contra spring is in fact a recycled matress spring.
Post by ahscoots on Oct 16, 2014 16:53:04 GMT -5
What spring should i order to replace it?
