After a bad rain if I use left brake scooter won't start also rear left and front right blinker don't work neither does brake light if I use left brake handle. Any ideas???
Most of these have a cheap little bottom that's used to activate brakeight and to show a brake is active during starting it should be under the handle bar near the brake.
Ok I don't understand this didn't do anything and left brake light works and can start scooter with left brake. Still got the blinker issue though.
Just try to keep the switches etc covered from the rain, or funny things tend to happen. I usually just cover mine with a trash bag. I've had to covers disappear. But apparently nobody wants a trash bag......lol
Well cant get scooter to start at all questioning bad starter switch as well as brake switches. Been having issues with this whenever things get wet. Usually when it dries will start but not anymore. Can the brake switches be bypassed by wiring together and to starter button wires to a regular push button switch.
Well, if it's an absolute must and you have no fear of being rear-ended or pulled over... Then take the wires from the brake switch and connect them together temporarily to start it.
If it's the starter button not working then you can jump the solenoid with a screwdriver or pliers.
These are just ways to start it. I'm certainly not suggesting you ride it.
www.youtube.com/watch?v=0eZRUFbfju8 49ccscoot.proboards.com/thread/16834/2005-zuma-aerox-motor 2005 Zuma 50 (Aerox 50 motor) Malossi MHR Big Bore 77 bbk, Malossi RHQ 12mm crank, Roost 86 pipe, Keihin 28mm PWK,Stage6 reverse intake manifold, Stage6 30m forks, Polini rear shock, Aerox 50 wheels, much more to list and many more upgrades to come... 2008 Zuma 50 2012 Zuma 50 (sold) 2003 Derbi Red Bullet 2006 Metropolitan
Ok my brake light does not get brighter when i try either one with key on but not started. I am able to start it by "jumping" selenoid. Just don't wanna do that all the time. So in not sure if its just the starter switch or also both brake switches
Has it had gas in it for 2 months while it sat? Could be bad.
You can check the brake switches if you have a multimeter. Look for no continuity between the 2 wires (multimeter should display 0L/OL) from one switch when it's not being squeezed. While squeezed it should display something near 0 ohms. If you don't get near 0 resistance with the lever squeezed, the brake light switch is not working.
If the brake switches appear to be working, see if one side of the wire has 12V+. You can also check that both wires have 12V+ when the lever is squeezed. If not, you need to find out why there is no power to the levers.
If you get power in and out of the brake switches, then see if you get power to the starter solenoid on one of the small wires, not the large cables from the batt and to the starter. It cranks when you jump the large cable terminals, so you know those 2 cables are doing their jobs.
