Post by freedomrider73 on Oct 25, 2014 17:26:32 GMT -5
Ok working on a viva scooter for a friend 50cc 2 stroke with a 28mm lippo carb jets were totally plugged and i need to replace what size are the originals and where do you recommend looking also what would be a good replacement carb? it is a flanged model that bolts to the head, its for a teenage girl so ride ability and reliability are most important, speed and performance aren't thanks guys
carb jets
Oct 26, 2014 0:24:37 GMT -5
via mobile
Post by Clank on Oct 26, 2014 0:24:37 GMT -5
:welcome2: Check the tech library. There's and index in the front that should point you in the right direction. Either that or wait till your post catches one of the 2stroke pros eye for a better reply.
Post by 2TDave on Oct 26, 2014 5:32:49 GMT -5
I'm not familiar with that carb but you should be able to clean the original jets. Soak them in carb cleaner and hit them with compressed air.
Post by freedomrider73 on Oct 26, 2014 10:04:16 GMT -5
I soaked them for a day and the build up was so bad I had to drill them out. Went a little too big so it runs way to rich now.
Post by moofus02 on Oct 26, 2014 10:44:33 GMT -5
I soaked them for a day and the build up was so bad I had to drill them out. Went a little too big so it runs way to rich now. You could solder them closed and re drill smaller Sent from my SPH-L720 using proboards
Post by niz76 on Oct 26, 2014 21:58:29 GMT -5
Post by 90GTVert on Oct 30, 2014 9:09:14 GMT -5
28mm is not the carb of choice for reliability and ride-ability on a 50cc. I don't know about that model, but typically 14-17mm carbs are stock on 50cc 2Ts. 19mm would be as far as I'd go for stock.
