Post by dudescoot on Nov 3, 2014 19:35:39 GMT -5
Ok so as most know I've been tuning retuning and retuning again thought I had finally got it there, then I ran out of gas accidentally and the carb pulled up some crap out of the gas tank. So I cleaned out the tank filled several shot glasses with metal. Though the inside of the tank looks fine? Scratching my head on that one. Cleaned the lines fuel pump and carb as well as a new fuel filter. Started it up and it was running like a champ as long as 1/4 throttle was all I needed to ride it's a rocket under 1/4 throttle but anymore than that and it bogs hard until I release the throttle? As far as I can tell everything is as it should be.
Post by Elektrey on Nov 3, 2014 20:50:04 GMT -5
I know this isn't the answer your looking for but, retune again.
Post by katastroff on Nov 3, 2014 20:55:23 GMT -5
I know this isn't the answer your looking for but, retune again. Yup, i'd give a go at cleaning it again first. Could be some crap still stuck in your jets.
Post by dudescoot on Nov 3, 2014 22:04:02 GMT -5
I think I left a part out if I hold it at 1/4 throttle or less for a bit then hop on it it'll take off for a second before bogging like the bulb isn't fully filling?
Post by niz76 on Nov 4, 2014 0:19:29 GMT -5
Check the float level in the carb- might not be getting fuel fast enough to supply over 1/4 throttle...
Post by scooterpimp on Nov 4, 2014 5:36:18 GMT -5
Don't get irratated , walk away for a while , then return with clear head.
Post by dudescoot on Nov 4, 2014 7:34:08 GMT -5
I've been walking away and coming back for weeks now lol this thing hates me
Post by katastroff on Nov 4, 2014 8:49:55 GMT -5
If there is one thing in life one must not do, it's to give up.
Post by dudescoot on Nov 4, 2014 9:16:51 GMT -5
I'll never give up it doesn't take being away long for my curiosity to build and new ideas to come up then I'm back at it. My bikes toying with me.
Post by Corrosion on Nov 4, 2014 11:48:09 GMT -5
Have you replaced all the Fuel lines. If they deteriorate, it all goes into the Carburetor.
Post by dudescoot on Nov 4, 2014 15:29:18 GMT -5
I believe I've found the culprit, I'm not sure exactly what it's called I've seen it called the manifold vacuum? When the throttle spring turns it pushes the needle of this piece down and it's like a pump? The jet inside this piece was clogged I cleaned it up put it back together and just my luck now the engines not getting fuel so when I get back to the house I'm gonna pull the fuel pump apart and see whats up hopefully that small pump on the carb wasy problem and that's why it was running like a dog.
Post by birdman on Nov 4, 2014 16:38:59 GMT -5
So your main jet was clogged?
Post by scooterpimp on Nov 4, 2014 18:26:12 GMT -5
I believe I've found the culprit, I'm not sure exactly what it's called I've seen it called the manifold vacuum? When the throttle spring turns it pushes the needle of this piece down and it's like a pump? The jet inside this piece was clogged I cleaned it up put it back together and just my luck now the engines not getting fuel so when I get back to the house I'm gonna pull the fuel pump apart and see whats up hopefully that small pump on the carb wasy problem and that's why it was running like a dog. Accelerator pump is what the call it, verify vacume petcock flows gas when you add vacume to vacume port of it. (Dont suck on wrong part or you will drink gas... if fuel filter is bronze type get rid of it for paper or screen type. Once you have good flow to carb. Clean it well , sometimes spray carb cleaner isnt strong enough ,i use bread bag twisties with paper removed to twist through jet holes. Then check for light through them. Just tossing some ideas out there.
Post by dudescoot on Nov 5, 2014 16:48:29 GMT -5
So come to find out it's not the carb the fuel pump wasn't feeding enough gas to go faster than 2 miles an hour. All those times taking the carb apart for nothing
Post by katastroff on Nov 5, 2014 17:06:01 GMT -5
A clean carb is a happy carb.
