Post by ohdanny on Nov 11, 2014 18:31:15 GMT -5
Hi, I have a TGB Sunset 49cc 2stroke franco morini. I need to replace crankshaft, I screwed out and in the Vari nut as a normal non reverse thread, I believe it's gonna fall of, if anyone could help on telling me the steps to disassembly engine and get out the crank I would be infinitely thankful.
Post by 190mech on Nov 12, 2014 5:46:10 GMT -5
If the crank is going to be replaced and the variator nut/threads are stripped,cut it off with a cut off wheel on a Dremel.The rest of the teardown is like a Minarelli type engine,,look in the tech section for manuals(1E40QMB) and go from there,,you'll need a flywheel puller and a crankshaft pulling tool also,Be very careful installing the new crank,no hammering or pressing as it WILL mess up the runout!
Post by ohdanny on Nov 12, 2014 11:10:34 GMT -5
Thank you for rour answer it is very helpful. I took the nut out couterclock with a impact gun, that is when I crossthreaded crank and nut, now I can tighten clockwise, is this safe? or just replace crank?
Post by 190mech on Nov 12, 2014 12:22:01 GMT -5
I doubt it will hold,but if it will torque down,it may be worth a try...
Post by jhobe6678 on Nov 12, 2014 12:52:53 GMT -5
I doubt it will hold,but if it will torque down,it may be worth a try... Would re-threading it even be an option?
Post by 2TDave on Nov 12, 2014 14:27:32 GMT -5
Are they reverse threads on a Morini? Never heard that.
Post by ohdanny on Nov 12, 2014 14:36:02 GMT -5
I would rather to tap and die the problem, to one smaller size. But I dont know if it would be a reliable final solutuon.
Post by ohdanny on Nov 12, 2014 14:49:51 GMT -5
Are they reverse threads on a Morini? Never heard that. Well.. the variator fan were the nut sits indicates with an arrow to the right to unlock
Post by jhobe6678 on Nov 12, 2014 14:51:15 GMT -5
Are they reverse threads on a Morini? Never heard that. Well.. the variator fan were the nut sits indicates with an arrow to the right to unlock Time for someone to Google this...
Post by 190mech on Nov 12, 2014 15:14:43 GMT -5
Are they reverse threads on a Morini? Never heard that. Yep!Left hand threads on the vari side..If you can run a die(rh thread) next size smaller on the crank,that should be a good repair,maybe loctite it too...
Post by ohdanny on Nov 12, 2014 15:50:09 GMT -5
[quote source="/post/145804/thread" timestamp="1415820452" author=" 2TDave"]Are they reverse threads on a Morini? Never heard that. Yep!Left hand threads on the vari side..If you can run a die(rh thread) next size smaller on the crank,that should be a good repair,maybe loctite it too...[/quote] Ok then.. , thank you all for the help I will be trying the "right hand die?" One size smaller, To thred back to reversthread, only I have to build a tool for turning the die in such reduced space. Thank you all again.
Post by 190mech on Nov 12, 2014 20:02:13 GMT -5
Post by ohdanny on Nov 12, 2014 22:49:15 GMT -5
Thank's a thous man, this manual is way better than TGB's plus i can se detail on images.
Post by 90GTVert on Nov 13, 2014 7:32:57 GMT -5
Post by ohdanny on Nov 14, 2014 1:25:34 GMT -5
[quote source="/post/145804/thread" timestamp="1415820452" author=" 2TDave"]Are they reverse threads on a Morini? Never heard that. Yep!Left hand threads on the vari side..If you can run a die(rh thread) next size smaller on the crank,that should be a good repair,maybe loctite it too... Ok then.. , thank you all for the help I will be trying the "right hand die?" One size smaller, To thred back to reversthread, only I have to build a tool for turning the die in such reduced space. Thank you all again. [/quote] 190mech said: If you can run a die( rh thread) - is this correct to make a new reverse thread??
