Post by mattjb on Nov 25, 2014 14:16:17 GMT -5
I have a used 2008 Adly Jet 50 and recently had brake problems, I checked the Brake Fluid Reservoir window and saw that it was dry and empty, so need to refill with DOT3 brake fluid. My question is, do I have to fully bleed the brake system or can I just open reservoir cylinder and add fluid? I am very low on funds so was hoping I could just top it off with new DOT3 fluid
Post by tiny on Nov 25, 2014 14:33:10 GMT -5
If you add brake fluid at any point when the reservoir is empty you need to flush out the system or you will get air bubbles and no braking power.
Post by mattjb on Nov 25, 2014 14:38:07 GMT -5
Ah I see, so what tools will I need to bleed the system? Can I buy them at a regular Tool Supply store like Loews or Home Depot?
Post by niz76 on Nov 25, 2014 14:39:53 GMT -5
I like this "coke bottle method"...
I've used this method twice and it works great!
Post by Mrx2002 on Nov 25, 2014 14:41:59 GMT -5
Here ya go!
Post by Elektrey on Nov 25, 2014 17:35:33 GMT -5
just locate the bleeder nipple, untighten it and stick on a 1/4 or 3/16 fuel line if you have any laying around or any other tube and point it to a cup and just bleed it while adding new fluid.
