Post by Mrx2002 on Nov 26, 2014 12:46:14 GMT -5
Okay i have been having issues with my scoot and WOT it just won't do it. Replaced the spark plug ran the scoot around the block still won't run past half throttle! Pulled the plug out to find this... Now i have a serious issue because with the engine running i can turn the air/fuel adjuster screw all the way in and it keeps running. If the screw is pulled back out to where it should be WOT on the stand sounds VERY choppy and there is lots of black smoke coming from the exhaust. The elec choke is working like it should be i pulled that out the body of the choke was warm and as it started cooling off the needle retracted. Im about to say screw it and get another carb....
Post by FrankenMech on Nov 26, 2014 13:38:10 GMT -5
What is the fuel level in the bowl?
Is there a leak in a diaphragm somewhere?
Post by Mrx2002 on Nov 26, 2014 18:41:39 GMT -5
What is the fuel level in the bowl? Is there a leak in a diaphragm somewhere? The top diaphragm looks great i'm not sure on the level of fuel in the bowl ill check that tomorrow. Im also going to look very hard for cracks something is leaking fuel i know with the air/fuel adjuster screw in all the way the engine should stall but it keeps running.
Post by FrankenMech on Nov 27, 2014 13:07:22 GMT -5
Check the vacuum hoses for gas. A leak in a petcock or pump diaphragm can add extra fuel.
Post by niz76 on Nov 27, 2014 17:58:49 GMT -5
A/f mixture screw shouldn't have an effect on WOT. Adjust the screw so you have good idle and throttle response to 1/4 throttle and change the Main Jet for tuning WOT. (the needle-along with MJ tunes mid-throttle)The airbox snorkel can be a good tuning tool- if you think you're running rich, take the snorkel out which lets more air in and leans the mixture- if it runs better then you can use that as a clue to go leaner with the Main Jet...
Post by Mrx2002 on Nov 28, 2014 17:30:57 GMT -5
Post by FrankenMech on Nov 28, 2014 19:37:23 GMT -5
Good to hear it wasn't anything major.
If that jet keeps falling out a tiny divot in the jet threads will usually tighten it up enough to keep vibration from loosening it.
Post by Mrx2002 on Nov 28, 2014 19:38:27 GMT -5
Good to hear it wasn't anything major. If that jet keeps falling out a tiny divot in the jet threads will usually tighten it up enough to keep vibration from loosening it. Okay ill keep that in mind! Thanks for the tip man!
