Post by devinchasteen15 on Dec 7, 2014 15:33:59 GMT -5
Is it bad to leave a 50cc 139qmb moped sitting for a few weeks with out oil? I bought one in Kentucky while I was there and I couldn't get it to fit in my vehicle Lol. The guy I bought it from drained the oil because he said I need to change it. I won't be back in Kentucky until the 20th and it will be sitting with no oil will this cause any problems please help
Post by Elektrey on Dec 7, 2014 16:30:40 GMT -5
I dont see how as long as it's not used without oil
Post by devinchasteen15 on Dec 7, 2014 17:22:29 GMT -5
I dont see how as long as it's not used without oil OK its not going to be used until I get new oil in it.
Post by Elektrey on Dec 7, 2014 17:35:10 GMT -5
I dont see how as long as it's not used without oil OK its not going to be used until I get new oil in it. then yeah should be fine. I don't know much about 4 strokes so maybe i'm wrong but common sense tells me your good.
Post by Clank on Dec 7, 2014 18:05:51 GMT -5
Don't start it right away after you add oil. You need to hand crank it over a few times so the pump can start getting oil to the valves. I'd. Pull the sparky and remove the valve cover after hand cranking it then turn it intermittently with the starter until you see oil up at the valves. Put the valve cover back on then your sparky then see if it'll fire. :2cents:
Post by devinchasteen15 on Dec 14, 2014 13:30:51 GMT -5
Don't start it right away after you add oil. You need to hand crank it over a few times so the pump can start getting oil to the valves. I'd. Pull the sparky and remove the valve cover after hand cranking it then turn it intermittently with the starter until you see oil up at the valves. Put the valve cover back on then your sparky then see if it'll fire. How do I hand crank it
Post by 90GTVert on Dec 14, 2014 14:05:26 GMT -5
Use the kick start and turn it over slowly. Feet work too, just don't kick it over hard for the purposes Clank mentioned.
Post by devinchasteen15 on Dec 15, 2014 0:13:17 GMT -5
Use the kick start and turn it over slowly. Feet work too, just don't kick it over hard for the purposes Clank mentioned. Kind of a problem there as I don't have the kick start. Any other ways to hand crank it
Post by Elektrey on Dec 15, 2014 0:33:35 GMT -5
Locking pliers on the kick start nub thing and just rotate them; Don't strip the pattern on the knob!
Post by devinchasteen15 on Dec 15, 2014 1:06:16 GMT -5
Locking pliers on the kick start nub thing and just rotate them; Don't strip the pattern on the knob! I have no parts of the kick start at all. I defiantly plan on replacing it. Any ways to hand crank from here
Post by Clank on Dec 15, 2014 2:11:19 GMT -5
If you take the fan shroud off and remove the fan you can turn the flywheel by hand. There's an arrow indicating which direction the engine rotates. Typically clockwise.
Post by Mrx2002 on Dec 15, 2014 3:58:28 GMT -5
You can pull the spark plug and just use the starter it won't hurt the engine at all. Just make sure your getting oil to the top end before you put the plug back and start the scoot. My scoot (Dusty) sat for almost 9 years with no oil in it and its fine i just pulled the valve cover and made sure there was oil being pumped through to the valves.
Post by scooterpimp on Dec 15, 2014 5:53:16 GMT -5
Short quick bursts with starter a few times. After oil is added........l
Post by devinchasteen15 on Dec 15, 2014 16:58:18 GMT -5
Short quick bursts with starter a few times. After oil is added........l So just press the starter button and let off it before it starts up in short bursts
Post by scooterpimp on Dec 15, 2014 17:59:08 GMT -5
2-3 second bursts , a few times. Then connect spark plug & go.
