tvnacman
Post by tvnacman on Dec 10, 2014 16:32:21 GMT -5
it should run at 3 4 and 5 . you need to get it to run first . How many times has this happened ? What are the guys at the shop doing to get it to run ? Who installed the BBK ?
John
Post by blaq on Dec 10, 2014 16:41:13 GMT -5
This has been going on for about month and a half going on two months. The one time I did see him actually working on it I bought him the brand spanking new carburetor he choked it manually and it started right up and died and he started back up and then it died again and then started back up and then he told me ride around and I rode around that it didn't cut off
Post by blaq on Dec 10, 2014 16:42:03 GMT -5
it should run at 3 4 and 5 . you need to get it to run first . How many times has this happened ? What are the guys at the shop doing to get it to run ? Who installed the BBK ? John They also installed the BBK that I purchased for them
tvnacman
Post by tvnacman on Dec 10, 2014 16:48:22 GMT -5
I can tell you in the cold on my 150 with pod filter and performance exhaust below 50 degrees . My scooter was a hard start . When I put in a larger pilot jet that went away .
John
tvnacman
Post by tvnacman on Dec 11, 2014 7:38:16 GMT -5
bump , decide not to work in snow .
John
Post by Clank on Dec 11, 2014 7:53:34 GMT -5
When you say 3 and five do you mean .003inch? Or mm?
Post by blaq on Dec 11, 2014 7:57:51 GMT -5
What ever it is on the feeler gauge I read instructions I found the only settings that said those number whether its inch /mm idk I'll have to get up and check the package to the feeler gauge
Post by Clank on Dec 11, 2014 8:05:20 GMT -5
Well if you set it at .03 instead of .003 that would create a serious loss of compression.
Post by iwannascoot on Dec 11, 2014 8:06:19 GMT -5
I would be very unhappy with the shop that installed my BBK and could not make it run. It seems to me they should know what is wrong and make it right for you.
Billy
Post by blaq on Dec 11, 2014 8:11:22 GMT -5
I am...
Post by blaq on Dec 11, 2014 8:13:21 GMT -5
There were two 00's clank
Post by Clank on Dec 11, 2014 8:17:38 GMT -5
Are you sure you're getting fuel,spark,air,and compression?
Post by blaq on Dec 11, 2014 8:27:24 GMT -5
Yes myself I checked spark fuel air I'm not to sure how but I took the air filter off so I would think so I feel it sucking air through the carb compression I should have the mechanic say everything is correct he can't figure out why it does it
tvnacman
Post by tvnacman on Dec 11, 2014 8:29:57 GMT -5
your using a stock pilot jet in a bbk and your not able to start in 33 degree weather . What kind of air filter and exhaust performance or stock ?
John
Post by Clank on Dec 11, 2014 8:34:48 GMT -5
Are you getting fuel? There's usually a hose connected to the bottom of your carb bowl that runs down in front of your CVT cover and is secured with one of the CVT cover bolts. Take a standard or flat blade screwdriver and open the valve at the end of the hose. Put something under it to catch the gas. See how much comes out.
