tvnacman
Post by tvnacman on Dec 11, 2014 9:38:37 GMT -5
recheck for spark while your there .
John
Post by blaq on Dec 11, 2014 9:44:34 GMT -5
I went out the other day brought a new NGK so I know I'm getting spark
tvnacman
Post by tvnacman on Dec 11, 2014 9:50:20 GMT -5
I went out the other day brought a new NGK so I know I'm getting spark Putting a new plug does not mean your getting spark . You need to check for spark . John
Post by blaq on Dec 11, 2014 9:57:41 GMT -5
When the coil gives you a shock of your life you'd think that there would be spark
Post by iwannascoot on Dec 11, 2014 10:08:39 GMT -5
You said you were going to try gas in the "vac line" Which particular line is that. There is one that is between the carb and the head. That would get gas to the cylinder.
Put your new plug on the coil wire, ground it to the engine (not the frame) and check for spark. If you have a good spark then install the plug, put some gas into the vac line and try to start it. Let us know what happens.
How cold is it where you are doing this?
Billy
Post by blaq on Dec 11, 2014 10:09:43 GMT -5
Today high of 38 I think
Post by Clank on Dec 11, 2014 10:13:59 GMT -5
:no: I'm going back to coaching girls volleyball. :banghead: good luck with your scoot bro.
Post by iwannascoot on Dec 11, 2014 10:15:57 GMT -5
It's going to take some luck to get his going Clank...
Billy
Post by blaq on Dec 11, 2014 10:32:48 GMT -5
The first time I sprayed starter fluid a puff came out back tried to start second time with petrol no smoke nothing happend
Post by blaq on Dec 11, 2014 10:58:57 GMT -5
I'm going back to coaching girls volleyball. good luck with your scoot bro. Just curious If compression is the problem what would you do to fix it? Billy , I have been there wet hand and no start . low compression will do that . He is all over the place trying to get this to run too . John
Post by Clank on Dec 11, 2014 11:15:23 GMT -5
A rebuild
Post by blaq on Dec 11, 2014 11:23:32 GMT -5
Oh no that basically what I paid for this MF bout to get a ear full right now Cuz if ppl on the net is getting puzzled about what's going on with my bike is crazy Cuz b4 I brought my bike to him it ran like a champ ran so much it didn't cut off that's the main reason I brought it to him then I said while its in the shop let me go ahead and upgrade the cc's so i can get over these NYC bridges just a Lil quicker FML I swear yo omg
tvnacman
Post by tvnacman on Dec 11, 2014 12:29:59 GMT -5
You could have a blown engine , no one here has seen your scooter , it's symptoms or other . From what you say , if what you say it true . It's fuel or timing , this us something we need you to figure out .
John
Post by blaq on Dec 11, 2014 12:36:05 GMT -5
Is air supposed to blow out the how's on the head That goes to the air filter?
tvnacman
Post by tvnacman on Dec 11, 2014 13:42:15 GMT -5
Air is blowing back to the air filter ?
