Post by 90GTVert on Dec 15, 2014 22:17:29 GMT -5
Mine doesn't use bolts for the seat bucket. It has M6x1.0 studs on the frame and just uses nuts (and washers) to hold the seat down.
Post by devinchasteen15 on Dec 15, 2014 22:26:05 GMT -5
Mine doesn't use bolts for the seat bucket. It has M6x1.0 studs on the frame and just uses nuts (and washers) to hold the seat down. Yeah I get my nuts and bolts mixed up. There is studs on the frame where the seat bucket goes,so I really just need some nuts and washers
Post by 90GTVert on Dec 15, 2014 22:54:16 GMT -5
Don't buy standard M6 washers for that purpose. Look for a fender washer or something with a larger OD to spread the load out a little more. If they don't have them in metric, just go to the standard section and look.
Post by devinchasteen15 on Dec 15, 2014 23:35:53 GMT -5
Don't buy standard M6 washers for that purpose. Look for a fender washer or something with a larger OD to spread the load out a little more. If they don't have them in metric, just go to the standard section and look. OK thanks man
Post by scooterpimp on Dec 16, 2014 6:04:31 GMT -5
Can use thick 1/4" fender washers for the 6mm studs/bolts. Also metric flange nuts have a wide base .
