Post by lansingscootguy on Dec 30, 2014 5:51:19 GMT -5
Could this be why it doesn't seem like it is getting enough fuel?
Post by lansingscootguy on Dec 30, 2014 7:58:35 GMT -5
Tried to tighten up the screw and can't turn it. What do I try now?
Post by iwannascoot on Dec 30, 2014 8:03:13 GMT -5
Post by niz76 on Dec 30, 2014 9:00:27 GMT -5
I've noticed that if the carb is leaking elsewhere- say out of the overflow for example- it can run down to the lowest point of the carb- the drain nipple - and appear as if it's leaking from there. An optical dilusion
Post by lansingscootguy on Dec 30, 2014 10:49:09 GMT -5
I have a new keihin carb ordered. Looking forward to putting it on.
Post by lansingscootguy on Dec 31, 2014 19:24:29 GMT -5
Got my new carbeurator on. Can't get it ajusted right. Watched the video on it and read the directions numerous times. Breathe breathe can only do so much in 17 degree weather. It won't idle period. Breathe breathe. Frustrated beyond all measure of sanity.
Post by Deleted on Jan 1, 2015 0:32:12 GMT -5
Got my new carbeurator on. Can't get it ajusted right. Watched the video on it and read the directions numerous times. Breathe breathe can only do so much in 17 degree weather. It won't idle period. Breathe breathe. Frustrated beyond all measure of sanity. Have you tried a bigger idle jet? Sounds like a lack of fuel
Post by Deleted on Jan 1, 2015 6:42:13 GMT -5
in 17 degree weather the air is more dense, thus an increase in O2 and requiring more fuel. Chokes stay on longer, sometimes they never completely go off. The engines never come up to full normal operating temp even inside a service bay, so it becomes almost impossible to set a carb properly.
Post by Deleted on Jan 2, 2015 18:42:49 GMT -5
G can only do so much in 17 degree weather. Have you tried a bigger idle jet? Sounds like a lack of fuel 17 degrees? that is much of the problem right there. In all my years I have never seen any air cooled vehicle of any kind both start and run good in such low temps. I had the intake manifold of a '67 VW ice up one time and had to use a propane torch to thaw it out so it would start. All my scooters, even my low mileage honda, dont like to crank much below 40 degrees.
Post by lansingscootguy on Jan 3, 2015 8:24:30 GMT -5
I have been riding for 10 years in every kind of weather. None of my other scooters have had this problem.
Post by 90GTVert on Jan 4, 2015 23:24:22 GMT -5
If it won't idle at all then you need to turn up the idle speed till it can idle enough that you can adjust it or pull the carb apart and make sure the pilot jet is clean.
I've always had a hard time with any scoot using an auto-enricher in cold weather as far as idle quality till warm so I wouldn't expect a perfect idle. It will likely end up a compromise between what works cold and warm.
Post by lansingscootguy on Jan 5, 2015 8:00:26 GMT -5
Thinking about putting the stock carbeurator back on.
Post by Deleted on Jan 6, 2015 1:22:13 GMT -5
I have been riding for 10 years in every kind of weather. None of my other scooters have had this problem. what does a correctly performed compression test on this engine say?
Post by lansingscootguy on Jan 6, 2015 8:17:24 GMT -5
I don't have the tools for a compression test. Going to look for one when I get some money.
Post by Deleted on Jan 7, 2015 16:14:05 GMT -5
