Post by Thebatman on Nov 7, 2010 19:05:35 GMT -5
Hey fellas. figured id throw my threads into 1. I asked 90gt to replace a few pics here. i will send some of my exhaust port shortly. THANK YOU FOR YOUR HELP WITH MY PICS!...Visual mods are as follows: removed stickers, painted the silver pieces black, painted dash and floorboard black, chrome handgrips, polished cvt cover, red speedo/runnin lights, blacked out all lenses/w led tail lights,(in the process of now), complete S9 suspension/brake/wheel upgrade, upgraded size tires(130-120), removed rear rack/center stand, need to remove rear fender, installed a tach...Performance mods are as follows: upgraded tires, technigas next r chrome pipe, ported oem reed cage/intake, rejetted carb(current .965), open air filter, homemade "forced air induction", race var.(ebay)/w 5.1g malossi rollers, lightened adige clutch w/ncy2000 fly springs, malossi 1000 contra, currently in the middle of porting/matching my 1st exhaust port(going 4 1mm up,1mm each side)..i think i listed everything to this point. hope 2 hit next level
Post by 90GTVert on Nov 7, 2010 21:00:58 GMT -5
Post by 90GTVert on Nov 7, 2010 21:09:06 GMT -5
Cylinder Porting from thebatman : oem cylinder. exact match for a dio cylinder??? dio match?? found a dio bbk $100 CHEAPER than the zx bbk... when i first pulled it off last night.. see the new carbon??.. small exhaust...lmao dio match? ?? this is after a lil bit of work with the good ol trusty dremmel......lmao... this pic and the next pic are what she's looking like at THIS moment.. i am getting there....lmao.. i know it won't look like some of these mirrored ports since this is my 1st....lmao.. i just hope to god it's correct and i havent screwed something up.... keep your fingers crossed for me...lol....no, really......lmao another look at my current mirroring attempt.....lmao.. be back shortly with what i hope is the finished product...... far from the work of some around here...190mech for one...lol.... bout as shiny as i can get my 1st one i think.... now i am nervous, cant plug chop till tomorrow but i've never bit this bullet before......thanks for any and all the invaluble help you guys have given..... "THE BAT"MAN...
Post by 90GTVert on Nov 7, 2010 21:12:06 GMT -5
Lookin' good so far. Have you done anything to the port at the bore side yet?
Post by Thebatman on Nov 7, 2010 21:33:07 GMT -5
hey man, thanks a million.. cool deal.... actually, yeah i have.. i did my best to measure 1mm up, 1mm out on each side. of course my 1st time measurements werent perfect, so i tried to stay under my line...lol.. when looking in i should be close anyway.. tried to keep the slight curve on the bottom half of the port toward the header joint.. of course i could not find a "flex hone", to aid in my efforts to chamfer all the ports. i will have to return inside again...lol.. could i not "debur",for lack of better term, all the ports. the all have a rough cast look. getting a degree wheel printed so maybe i can learn and port ALL of em to the max....lmao
Post by 2strokd on Nov 8, 2010 8:33:16 GMT -5
Looks good to me :thumb:
Post by Thebatman on Nov 8, 2010 12:42:32 GMT -5
hey man, thanks... well, i pht hwr back together last night. started on the 2nd kick...wooo hooo...lmao... anyway, the last few days, my odle has absolutely sucked.. i can lean scoot to one side, itll die, lean the other way rpms jump up.. i just did 1 plug chop. pure white again.. could the porting lean it out like that??.(temps have dropped also, was good and dark brown, the rich side). i guess ill upjet again. already running a .965 jet. how will i know when carb is maxed out?(non removable pilot jet). keep in mind i STILL have that dam modded oem pipe on.. also it is windy today but i dont think i could even tell a difference with the porting..W.T.H? wheres my 3-4mph?..i was expecting a bigger difference for sure.. any ideas on carb would be great..
Post by 90GTVert on Nov 8, 2010 12:58:02 GMT -5
You ren't gonna gain much if you are out of tune now. Port work can definitely affect your state of tune. You would also be more likely to see gains with a tuned pipe since these mods are mostly for increasing high RPM power. If leaning from side to side changes your idle, I'd check float height or just stop leaning it at idle. lol You'll know when you are at your limits with the stock carb and it's pilot jet when you can't get it to idle well no matter how you adjust the mixture.
Post by Thebatman on Nov 8, 2010 13:19:40 GMT -5
hey 90gt, thanks for the reply.. lmao, yeah, i guess NOT leaning it may help huh.....i was thinking this started when i had put the s9 rear shock on last week. i didnt even think about it changing the float any. how do i know if it even needs adjusting?. the idle is pretty bad lately, was contributing to the cooler weather tho.. cant get a constant idle either.. well i guess i REALLY NEED my technigas pipe back on then huh?.. (i know the modded took away 4mph anyway). well i guess i did it semi correct since it didnt blow this a.m. here in these hills i kept having to UPJET instead of downjet with cooler temps like other ppl in these forums..
Post by 90GTVert on Nov 8, 2010 14:56:41 GMT -5
Usually the float sits about parallel with the base of the carburetor when you hold it upside down. Sometimes service manuals will give you a measurement to aim for. Also make sure the float needle and seat are clean and in good shape if you are in that far already. If you are leaning the bike very far, I don't really think it's an issue. Pretty normal. If you can't straighten your idle out then it may be worth checking for that reason. You are probably already well aware of this, but never set your idle when the scoot is cold. Always let it warm up first.
Post by Thebatman on Nov 8, 2010 15:39:45 GMT -5
if i rest it over on the kickstand is enough to shoot rpms up, leaned to right, it goes down to the point of stalling. yeah, imma try and upjet.. so i will check out the float, i knew back in the day, you adjust your float by bending the seat..i do hope imma upjet instead of suppose to DOWN jet. these dang ol' mtns. mess with ya...lmao... never have really understood the temps for jetting. ppl in greensboro will downjet this time of year, i had to upjet last time i tried..
Post by 2strokd on Nov 8, 2010 15:44:24 GMT -5
You will get it figured out. I always richen the mix as the temps drop.
Post by 90GTVert on Nov 8, 2010 16:57:37 GMT -5
Generally it's richer for lower temps and/or lower elevation and leaner for higher temps and/or higher elevation.
Post by 90GTVert on Nov 11, 2010 8:29:49 GMT -5
From thebatman : here is a before pic with my brake/wheel swap the other side the super9 front brake caliper going on my zx model the oem front caliper on the zx... i bet 2strokd can still ride it like this....lmao...wish i could, be kind of hard for me tho..(still too weak anyway..lmao) going back together.... man that caliper looks better.. 2 piston for better stopping....lmao the wheels also came from a super9.. a metal flake lime? ... all back together with a super9 brake/wheel.. i did cheat, i used the forks also... now i can say i have a complete s9 brake/suspension upgrade....wooo hoooo....lmao
Post by 90GTVert on Nov 11, 2010 8:35:04 GMT -5
Looks good. How do you like it?
