Post by 90GTVert on Nov 20, 2010 5:14:10 GMT -5
I don't know what to tell you on the gears really. I figure it's best to get the engine setup how you want it and then see what gears you think you need. If it's revved out and won't go as fast as you want, maybe it is time for an upgear. I usually end up liking the stock gears with the extra power though, so I can keep really increase acceleration. So far all of my 2Ts have been capable of 50MPH or better with stock gears. The Triton did 65MPH with stock gears, though it's known for having "highway gears". Even the Venus has seen 58MPH with the stock gears. But again, I have no clue what the gears are like on a ZX.
Post by Thebatman on Nov 20, 2010 12:38:02 GMT -5
this thing hasnt went as fast as i want YET...lmao.... i want to hit 65-68 after these parts are installed.. figure the bbk/carb would hook me up till 60, but i want 65, so that would involve gears..lmao..... josh had sent a number for some but those were primary , wouldnt think primary gona help top, the just for bottom correct?.... i apoligize for all the irritating questions.. i apoligize for all my questions fallin upon you too.... wish more would chime in.....lmao....oh well, i am slowly learning....
Post by 90GTVert on Nov 20, 2010 14:14:49 GMT -5
It doesn't matter primary or secondary can change the final drive ratio. They work together. The winning choice will either depend on what gears will get the ratio you want and/or if primary or secondary sets are easier to install for your scoot.
Post by Thebatman on Nov 21, 2010 22:07:47 GMT -5
i was thinking/read that an 8.5;1 would be the ticket....but what do i know...... i just want the whole package so to speak... :stumped: :burnout: wanna haul some booty :rockon:
Post by Thebatman on Nov 26, 2010 6:22:05 GMT -5
good morning guys...well my parts are starting to show up.got my bbk, multivar yesterday.. i am going with malossi bbk, lv zx pipe, 4 petal reed cage/24mm carb.. i have a few ? for you guys .........1) will i need to reset the squish band on the bbk?.......2)will i need to port the exhaust on the bbk like i did on the oem cylinder?(1mm up,1mm wider each side).........3)the piston has a boost port window, do i champfer this as well as the ports inside the cylinder?...........i need to split the cases on this one tho, i can already tell the boost port is bigger than oem. i wanna port the boost port and the intake tracts cause they are so smal on the zx.(got that carb, tracts will continue a restriction alond with the boost port)........4)on the boost port itself, you can see where its cut out for the boost port on the cylinder skirt, but pat ways the cut out is gone and you have the full skirt at the bottom.. shouldnt i match that or cut out that part of the skirt? it seems like this would rescrict the boost some. (can send a pic if needed, brent mybe point me in the right direction and i can try to post. i have a pc at the moment. :drool: i wanna do this right and not just slap it on and roll out ... i wanna haul ass :burnout: :rockon: '(for a scooter).... this will be alot different than a modded stock, now maybe i can catch some of you guys.. ;D ....... thanks in advance for youor help....
Post by 90GTVert on Nov 26, 2010 8:37:15 GMT -5
1) It needs to be checked at least. 2) I don't know what the Malossi kit is liek for your scoot. For Minarellis the Malossi sport revs around 800RPM higher than the Polini sport IIRC, so you may be satisfied with it as-is. Besides, you wouldn't HAVE to alter the port even stock. ;D 3) If the window has sharp edges, I chamfer it lightly. The main reason you chamfer the ports in the cylinder is ro reduce wear on the rings and reduce the risk of them snagging. That's not an issue on the window, so I don't think it's necessary, it just makes me feel better. lol I chamfer the skirt as well if it feels sharp. Again, I don't feel it's necessary and I'm just doing enough to knock the sharp edge off with emery cloth. 4) I think it would be a good idea to widen it to match the boost port and perhaps cut it a little higher. Here are pics of John's cylinder before and after... 49ccscoot.proboards.com/index.cgi?board=builds&action=display&thread=633&page=5There's an image posting guide here... 49ccscoot.proboards.com/index.cgi?action=display&board=general&thread=643&page=1#7984
Post by 90GTVert on Nov 26, 2010 14:21:11 GMT -5
Posted for batman...
Post by Thebatman on Nov 26, 2010 16:21:47 GMT -5
thanks brent...btw, name is larry. thanks for posting those pics... do you see what i was talking about on the cylinder skirt?...... is that normal?.. seen 190 had cut his out up thru the boost window...
Post by 190mech on Nov 26, 2010 16:31:12 GMT -5
Dang Larry,thats a long cylinder skirt!Can you post some pics of the cylinder from different angles,the piston,& the crankcase port areas?Let us see that and maybe we can come up with some good stuff for ya!
Post by Thebatman on Nov 26, 2010 16:54:04 GMT -5
i just sent brent a few more pics of the cylinder.. the skirt appears to be 1.120in/28.44mm long.. thanks for the reply 190,btw.....not sure if i took the pics you are speaking of but i can try again. .... i did notice that the piston keeps a portion of the small transfer port closed at all times tho...(both sides).. josh had mentioned also just to leave the cylinder porting out and reccomends doing the intake tract and the boost port tunnel, both on the case side of course, but you guys know that tho :doh:
Post by Thebatman on Nov 26, 2010 17:30:55 GMT -5
also plz excuse my stupidity. this is my 1st bbk, name brand no less...lmao.. anyway, there is not a marker on either ring saying t or b.. both look and measure the same. also thier isnt a ring expander like so in the oem rings... are both of these normal also? ? sorry so dumb guys but i am SLOWLY trying to catch up...lmao
Post by Thebatman on Nov 26, 2010 17:57:11 GMT -5
....................... trying this pic thing with the ONE pic i have in the puter so far... :swear:
Post by Thebatman on Nov 26, 2010 18:24:51 GMT -5
well i see i messed something up somewhere, this page is now bigger than the other pages.....w.t.h? oops, sorry guys.....
Post by 90GTVert on Nov 26, 2010 19:16:28 GMT -5
The pics fine. It's reduced to 800x600 as a max with some code in the forum anyway. ;D
If there are no markings whatsoever on the rings and they both look exactly the same, it won't matter which is where. If you have a locator pin in the ring lands, you should be able to tell which way is up by how they fit around that.
I'll check my email and get the pics up for you asap.
Post by 90GTVert on Nov 26, 2010 19:22:15 GMT -5
