Post by karolis on Jan 9, 2015 16:48:23 GMT -5
Hi guys, maybe ideas how to open this?? I tried about 20 minutes...
And how to turn this pin???
maybe this headlight not could be opened? need comments
Post by scooterpimp on Jan 9, 2015 19:32:59 GMT -5
Thats it , bulbs twist in from the back , most lenses are not removable. Just like most modern cars.
Post by 90GTVert on Jan 9, 2015 19:52:48 GMT -5
I'm guessing they use an adhesive like a lot of automotive headlights. Some of them can be taken apart after the assembly is baked at around 200F or heated locally with a propane torch to soften up the glue. You run a risk of damaging the assembly so most choose not to open them. If it's glued now it would need to be re-glued/sealed on assembly. If you're willing to take the risk you can find some vids and tutorials online searching for things like "separating headlight housing" or "baking headlight" I'd imagine. Might wanna price out a new headlight assembly and decide if the risk is worth whatever reward you're after. I'd imagine an Aprilia headlight assembly is not cheap and may not be easy to come by.
Post by iwiketuddlz on Jan 10, 2015 7:20:39 GMT -5
I used a heat gun on my CPI tracker..headlight very similar to a car...I worked my way around the lenses with the heat gun prying it until I got it apart,,then I reheated it on assembly and added some ultragray to seal it up...it took over an hour to do the process
Post by Sitticuss on Jan 10, 2015 8:34:17 GMT -5
why do you wanna open it? thats supposed to be a one way press on pin.
Post by tiny on Jan 10, 2015 10:18:20 GMT -5
What is that off of might I ask?
Post by birdman on Jan 10, 2015 12:12:27 GMT -5
custom projector HID set up or something in the works?
Post by karolis on Jan 11, 2015 4:34:59 GMT -5
I want to put leds, and squaring is bad.... I need put a little plastics to adjust lights because they droped from their location
