Post by jerry101 on Jan 15, 2015 14:39:27 GMT -5
hello everyone,im a newbee to this forum,and was wondering if someone can help me with my problem ? the problem i have is i have some play in the front part of my scooter,i get a front to back pulsing in my two arms when im riding ( doesnt really start till i reach about 10 mph ) im thinking its in the nut on the steering column,but i don't know how to disassemble the front cover were the front lights are located.any info would be appreciated,thanks
Post by niz76 on Jan 15, 2015 15:29:51 GMT -5
You're in the right place to get help! I have a similar issue on my scoot that I've been ignoring for too long now. I haven't done the repair yet but it could be as simple as removing the plastics on the front end to get to the nut and tighten it. It could be something a little more involved but you'll need to get in there to see regardless. Tons of good knowledgable folks here to help out with stuff like this! Good luck and happy scooterin!
Post by niz76 on Jan 15, 2015 15:31:34 GMT -5
Btw I only feel the play on mine when applying the front brakes heavily. If it's 'pulsing' while rolling it might point to another issue like unbalanced tire or something...
Post by scooterpimp on Jan 15, 2015 16:35:26 GMT -5
Crappy tire Or front brake hanging up, loose caliper ,rotor dead squirrel stuck in wheel?.
Post by Clank on Jan 15, 2015 17:04:37 GMT -5
I'll bet its your headset. It's similar to the old school goose neck style handlebar and fork on old bmx bikes. The but came loose which allows play in your steer tune. You need to remove the front plastics and get a couple of wrenches on the bearing race and lock not. Once you get the race snug then tighten the lock not against the bearing race to keep it from coming loose again
Post by Clank on Jan 15, 2015 17:05:44 GMT -5
My bad again, Hey welcome to the forum, you're in the right place out you love scooters.
Post by jerry101 on Jan 15, 2015 17:12:01 GMT -5
nice info,but not the info i was expecting, i want to find out how to take the front panel off,so i can tighten the nut.........
Post by Clank on Jan 15, 2015 17:17:36 GMT -5
nice info,but not the info i was expecting, i want to find out how to take the front panel off,so i can tighten the nut......... We need to know the make, model, and year of your scoot. Pics would be especially helpful.
Post by Fox on Jan 15, 2015 17:54:56 GMT -5
Not trying to insult your intelligence, but have you checked that your tire is properly inflated? These scooter tires can go flat and not look flat cause the side walls are pretty stiff.
Post by niz76 on Jan 15, 2015 18:45:04 GMT -5
nice info,but not the info i was expecting, i want to find out how to take the front panel off,so i can tighten the nut......... It's usually just a matter of locating the screws that hold the panel on and removing them... I guess if we knew exactly what scoot it was maybe someone could put up a pic with arrows pointing to the screws that say "remove these". What kind of scooter is it?
Post by Clank on Jan 15, 2015 19:31:02 GMT -5
My neighbor came up with a really quick way to remove the plastics. He layed it down at about 30mph the night before last. I don't recommend it but it is effective.
Post by jerry101 on Jan 16, 2015 8:57:36 GMT -5
the type of scooter i have is a 49cc vip 2014
Post by Fox on Jan 16, 2015 17:27:49 GMT -5
A loose steering head would not make a pulsing effect. It's either the brake disc is warped, the rim is bent, the wheel is horribly out of balance or you have a tire that is flawed (Not round). If it's a balancing issue, they make a product called "Dyna Beads" you put inside the tire. www.innovativebalancing.com/index.php
Post by jerry101 on Jan 17, 2015 9:10:06 GMT -5
what i noticed yesterday while sitting on the scoot and having hands on handlebars while pushing forward noticed there was play in the steering,thats why i figured it was this nut,while riding i get this up and back motion in both arms while holding onto the handlebars..
Post by Fox on Jan 17, 2015 11:01:37 GMT -5
If your scooter looks like the one below, then to get the front piece off you have to remove the little visor piece above the front wheel, then remove the big screw just under the headlights, and then remove the two screws above left and above right of the glove box. Then you pull down on the front panel to unlock the tabs and it will pop off. Disconnect the headlight plug and set it aside.
