Post by albongo on Jan 24, 2015 16:25:57 GMT -5
Guys I need some help. I'm planning to reinstall my exhaust tomorrow and have an exhaust crush gasket to fit during the procedure. I have seen them with the split on the side and this seems simple enough to fit but the one I have has the split on the top or bottom depending on your view. My question is which side should the split go? Next to the engine? Or next to the exhaust? I have Google it but can't find any answers.
Post by niz76 on Jan 24, 2015 16:53:57 GMT -5
I don't think it much matters but I could be wrong... Actually, i thought I was wrong once- turns out I was mistaken- I was actually right!
Post by albongo on Jan 24, 2015 18:40:25 GMT -5
Hahaha thanks niz. If nobody can help me I'll take a guess and record what happens.
Post by katastroff on Jan 24, 2015 20:12:01 GMT -5
Im a big fan of the oval gasket like this baby:
Post by scooterpimp on Jan 24, 2015 20:17:31 GMT -5
Just Close your eyes & slap it in place.
Post by Fox on Jan 24, 2015 21:12:10 GMT -5
I say put the split toward the engine. That way it's up inside the recessed area. Might make a difference.
Post by albongo on Jan 25, 2015 10:58:41 GMT -5
Ok I put the gasket in with the split towards the engine.
I will post the outcome soon.
Post by albongo on Jan 25, 2015 11:02:55 GMT -5
Katastroff I only have the ring gaskets but I will look into getting some of those.
Do you find it gives a better seal?
Scooterpimp I usually just see what happens but I'm trying to be a little more sensible this time.
Post by katastroff on Jan 25, 2015 11:26:41 GMT -5
Yup, i think they seal better and they cant go out of allignment when you screw on the pipe.
Post by niz76 on Jan 25, 2015 12:50:07 GMT -5
Im a big fan of the oval gasket like this baby: Those are the ones I prefer also.
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Jan 25, 2015 20:19:43 GMT -5
Oval gaskets for sure !!!! only way to go !!!!
Post by albongo on Mar 8, 2015 11:27:31 GMT -5
Ok to close this thread I fitted the ring gasket with the split towards the engine and applied sealant to the exhaust face, it seems to have created a good seal. I have seen no signs of the leak after about 50 miles riding. I'll keep an eye on it and post back if it changes.
