Post by devinchasteen15 on Jan 28, 2015 16:01:12 GMT -5
Would any of these wire harness work for a 2013 tao tao atm 50 a1
Post by 90GTVert on Jan 28, 2015 16:34:38 GMT -5
Post by devinchasteen15 on Jan 28, 2015 18:13:44 GMT -5
Oh lol my bad I forgot to upload a picture of them
Post by devinchasteen15 on Jan 28, 2015 18:17:17 GMT -5
I would order off them but every time I add the harness to my Cart it shows up red and I think that means its out of stock. So I'm trying to find another wire harness that would work
Post by 90GTVert on Jan 28, 2015 22:13:56 GMT -5
Try their email or scooterelement is a member here so maybe they can help that way. If either worked it'd be the 6-8. I see that it says "long" so I suspect it's a harness for the larger scoots. Not that it couldn't work with some effort. There are universal sort of harnesses that may have all of the connections, but different scooters put things in different places so if you can find one meant for the sunny style scoots or specifically the ATM50 then I think you'd have an easier time with the replacement.
Post by devinchasteen15 on Jan 29, 2015 9:59:42 GMT -5
Try their email or scooterelement is a member here so maybe they can help that way. If either worked it'd be the 6-8. I see that it says "long" so I suspect it's a harness for the larger scoots. Not that it couldn't work with some effort. There are universal sort of harnesses that may have all of the connections, but different scooters put things in different places so if you can find one meant for the sunny style scoots or specifically the ATM50 then I think you'd have an easier time with the replacement. I only need a new carb choke wire connection.
Post by devinchasteen15 on Jan 29, 2015 10:00:31 GMT -5
I don't know what the connevtons are called to order one so i might just get a new wire harness
Post by 90GTVert on Jan 29, 2015 10:21:45 GMT -5
Post by scooterelement on Jan 30, 2015 8:09:23 GMT -5
We have the cable in stock. If you need something email me to scooterelements@hotmail.com, like 90 say, the cable are universal Scooter Cable. The guys here mount a complete cable kit with all the light, speedometer and everything already conected or marked to where you should plug it.
