Post by 180°off on Feb 10, 2015 11:54:07 GMT -5
I was trying to do a custome strech on my vip scoot and when I put it back together the tail light and turnsignals decided that they did not want to work anymore? Does anyone know why? I need a lil help on this one because im no good at electrical. Thanks
Post by 90GTVert on Feb 10, 2015 16:08:23 GMT -5
All turn signals don't work or just the rear? Check your connections over. The rear lights may all share a common ground or grounding branch point in the harness so perhaps something is awry there.
Post by 180°off on Feb 12, 2015 17:04:20 GMT -5
all my turn signals do not work. Also I just noticed that the horn isnt working either. and i forgot to mention that my instrument cluster is not working either
Post by 90GTVert on Feb 12, 2015 18:49:17 GMT -5
Have you checked the fuse? Should be near the battery.
Post by 180°off on Feb 24, 2015 20:12:22 GMT -5
switched wiring harness with another one and still no lights. I am running with no battery so I should not need a fuse right??
Post by Clank on Feb 25, 2015 5:25:43 GMT -5
You need a battery to run your taillight, turn signals, horn, and instrument cluster. Only things that run on the stator is headlight and spark plug.
Post by 180°off on Feb 27, 2015 9:49:33 GMT -5
Well that is not true! Ive been driving my moped for about 6 months now without a battery and all my lights and horn worked just fine!Maybe my stator went bad?
Post by 90GTVert on Feb 28, 2015 10:11:57 GMT -5
