Post by Fox on Mar 5, 2015 16:10:14 GMT -5
Have you been looking at the spark plug between all these adjustments? It's important to check it after each ride so you can get an understanding of what needs to be done. Use a soft wire brush to clean off the plug each time before you reinstall it. This one looks perfect
Post by kostastmax on Mar 13, 2015 8:21:43 GMT -5
Hi there again thanks for all helping After some tests i think i got it Im running now main jet 98 the needle is in the middle position and after playing a llitle with the iddle mixing screw i think the engine now works great and the spark plug finally has that brown colour thanks a lot guys Now i will start to play with rollers and clutch spring to make it a little bit faster on acceleration Thanks again!!!!!!!!!!
