Post by humanshield on Feb 25, 2015 15:10:03 GMT -5
Been having a odd problem with the 100cc BBK
It's doing pretty good EXCEPT......
I'll be riding along and it "snarks" or "gasps" or "Wops" on me periodically and I have yet to figure it out.
What I mean by those terms is that I'll be riding along doing fine then all of a sudden, for just an instant, it acts as if it completely dies and makes a duck like noise then resumes. Nothing I've done seems to help.
I have a new head on it and I would swear the intake valve is sticking now and then. It happens randomly and mostly at higher throttle during cruise. It's a similar sensation to a HUGE gust of wind hitting you. The scooter drops 3 - 5 mph and then keeps going.
Reason I say intake valve is because I believe the noise I'm hearing is coming back up through the carburetor.
The valve doesn't have to stick wide open...juuuuust a teenie tiny bit enough to lose compression on that stroke.
I guess I'd have to slap a different head on there to be sure but I don't have another good head to try on it.
FWIW...it seems to be progressing a bit and getting a little worse with time.
Here's what I tried.....
Different Carburetor (No change)
Removed Muffler (No change)
Adjusted valves (No change)
Jetting changes (No change)
New Spark plug (No change)
New Coil (No Change)
New Spark plug cable (No change)
Removed intake (No Change)
Raised Carb Needle (Ran richer but problem still there)
Lowered Carb Needle (Ran leaner but problem still there)
Prayed (No change)
Cussed and swore at it (No change)
I got the kit from 02Starrider off ebay and his kits are great but I'm coming up empty on this one and my gut feeling is it's a sticking intake valve. I'm running outta idears.
Anyone got any suggestions on this odd ball issue?
Prayed (No change)
