Post by bran1har on Mar 3, 2015 16:37:50 GMT -5
I have a 2011 VIP 50cc scooter. It only has 100 miles on it. I bought it not running for cheap. It has issues starting. Forget kickstarting it, or just with the battery. You have to jump it with a car and crank and crank and crank forever and then it will finally start. The whole time you are cranking it, it will kinda sputter and smell like gas. Once it gets started tho, it will idle and drive real nice. But if you let it die or shut it off, forget about starting it again, you have to jump it and go through the same long cranking process again. Now i dont think this would have anything to do with it, but I live in CT and its really cold. About 20 degrees for the past few days but i dont think that should matter. I have a 150 the starts no problem in the cold. Things I've already done, checked for spark (has good spark), checked compression (150psi), new spark plug (it is wet with gas when i pull it out, cleaned the carb well, new cdi, new coil, adjusted valves to .004 and .005'', checked timing marks and camshaft, checked for vacuum leaks. Seems like it has everything it needs to run. Any insight would be greatly appreciated .
Post by blaq on Mar 3, 2015 16:42:37 GMT -5
Check Jets, air filter and mixture screw
Post by blaq on Mar 3, 2015 16:44:01 GMT -5
That sounded like my problem i just needed a bigger idle jet and she starts every time took mine out today
Post by daath on Mar 3, 2015 17:18:32 GMT -5
Check the bowl float as well. It could be flooding out due to it not sitting properly. I noticed the one I am working on flooding out and checked the float bowl and it wasn't set properly. That's my $.02
Post by bran1har on Mar 3, 2015 19:49:23 GMT -5
makes sense to put a bigger slow jet but it wont even start with the throttle wide open or if i give it a sniff of ether. It sputters but it just seems like the timing isn't right or something, but it is(checked flywheel key too).
Post by daath on Mar 3, 2015 20:41:22 GMT -5
The plug being wet could be a sign of flooding. I noticed it with my solana as well as noticed gas going up the hose to the airbox. The solana wasn't wanting to start and when it did it would sputter not to mention I'm having trouble getting it to run exactly right now due to a 130 main jet in it. I adjusted the float earlier today and hope it doesn't flood on me again.
Post by stuckchuck on Mar 3, 2015 21:00:45 GMT -5
check your valve lash on the compression stroke right?
Post by daath on Mar 3, 2015 21:22:23 GMT -5
No check it at top dead center.
Post by stuckchuck on Mar 3, 2015 21:26:19 GMT -5
a four stroke has two tdc's . do it on the compression stroke
Post by daath on Mar 3, 2015 21:28:56 GMT -5
I forgot about that. I'm tired right now and in a bit of knee pain so I easily forget stuff
Post by Fox on Mar 3, 2015 22:02:20 GMT -5
It's gotta be a tight valve. You adjust the valves with the cam in this position. It's TDC which is neither a compression stroke or an exhaust stroke. It's TDC. You can rotate the engine with a socket on the center of the fan. Easy does it! It's plastic. Removing the spark plug helps.
Post by stuckchuck on Mar 3, 2015 22:11:34 GMT -5
It's gotta be a tight valve. You adjust the valves with the cam in this position. It's TDC which is neither a compression stroke or an exhaust stroke. It's TDC. You can rotate the engine with a socket on the center of the fan. Easy does it! It's plastic. Removing the spark plug helps. crank at tdc and cam as pictured, give the crank one revolution and look at cam it wont be lined up. the two only line up on compresion
Post by Fox on Mar 3, 2015 22:26:53 GMT -5
Yeah it lines up right after the compression stroke but not during it so why confuse people? It's TDC. The piston is at the top of it's stroke. daath may already know all about it anyway..
Post by stuckchuck on Mar 3, 2015 22:32:39 GMT -5
Post by daath on Mar 3, 2015 22:35:16 GMT -5
Yeah I do. I'm tired been up all day in pain and looking at getting back to work on the solana in the morning. I'm also thinking about asking the guy around the corner who ha a 250 tarped up if he wants to part with it and if he does I'll have a flip scooter on my hands after I get done getting the solana back up and running.
