thattaotaothough
Scoot Junior
Curse you weather!
Post by thattaotaothough on Mar 26, 2015 10:38:37 GMT -5
As I posted that the spark plug was put in my mailbox LOL So now I've got both!!
.... Do I need a special tool to install a spark plug?
Post by 90GTVert on Mar 26, 2015 10:46:38 GMT -5
A spark plug socket is ideal for plugs, but you can use a deep 5/8" or 16mm socket.
Sounds like the batt replacement is needed if you want to use e-start.
The hard starting and running IMO is normal in cold weather. When it's much below 50F I have to babysit the scooter for the first couple of minutes... or set the idle speed higher than I'd like so it stays running.
thattaotaothough
Scoot Junior
Curse you weather!
Post by thattaotaothough on Mar 31, 2015 15:16:52 GMT -5
A spark plug socket is ideal for plugs, but you can use a deep 5/8" or 16mm socket. Sounds like the batt replacement is needed if you want to use e-start. The hard starting and running IMO is normal in cold weather. When it's much below 50F I have to babysit the scooter for the first couple of minutes... or set the idle speed higher than I'd like so it stays running. Thanks for the input! I got my new battery in and it fits great. Starts up right away. A problem I'm having now though, is if I slow down or am at a stop for too long. It stops running. Does that have something to do with the idle speeds? It hasn't become a serious issue because it starts right back up again, but for it to be doing that in the first place is worrying. And I don't like it. I did see a spark plug socket at Auto Zone, I'll be sure to grab it. Do I have to adjust anything to the spark plug itself? I think I'm also finding myself going open throttle a lot to keep up.. because again if I go too easy it just cuts out. I'm not to sure on what to do. Thank you for the help
Post by 90GTVert on Mar 31, 2015 15:32:13 GMT -5
thattaotaothough
Scoot Junior
Curse you weather!
Post by thattaotaothough on Mar 31, 2015 15:45:14 GMT -5
The carb is sealed I believe.. I do not have the tools you used in your videos to unseal it, so I can't get to the mixture.
But I'll try. Oh boy this is becoming quite the conundrum
When I get the chance again I'll see what I can do, it started to rain. I'll let you know what happens.
Post by stevec on Mar 31, 2015 18:46:11 GMT -5
the gy6 engines hate the cold, it can take a while before it stays running, my old taotao even when it was brand new took 15 min to warm up when it was cold out.
