Post by humanshield on Mar 23, 2015 18:05:08 GMT -5
Are you talking about the gray around the top bolt?
Yes that does look like an exhaust leaking past the bolt. Maybe you need a new gasket?
Did you check at the exhaust port at the cyl head? That's usually where the worst leaks occur.
Post by benitouk on Mar 23, 2015 20:30:47 GMT -5
I think I may have the same problem you had.. check this audio I recorded of my scooter when accelerating: vocaroo.com/i/s0GEfMgaBdX0Seconds 16 and 24 are very good examples The only two things I did was to replace the air filter box for a K&N cone filter, and the original exhaust for a LeoVince. Not sure if it started having this issue right after that though
Post by albongo on May 27, 2015 7:50:45 GMT -5
I think I may have the same problem you had.. check this audio I recorded of my scooter when accelerating: vocaroo.com/i/s0GEfMgaBdX0Seconds 16 and 24 are very good examples The only two things I did was to replace the air filter box for a K&N cone filter, and the original exhaust for a LeoVince. Not sure if it started having this issue right after that though Did you upjet when you changed the exhaust and airfilter?
Post by albongo on May 27, 2015 7:52:34 GMT -5
With all the other problems I had with the scoot, replacing the carb seems to have cured the cough/stumble. At least for now.
