boggin
Apr 20, 2015 21:20:04 GMT -5
via mobile
Post by thatcrazyguy on Apr 20, 2015 21:20:04 GMT -5
I have 80 mj in with airflow 1 turn out. Need to get a compression test goin tomorrow.
boggin
Apr 21, 2015 10:04:42 GMT -5
via mobile
Post by thatcrazyguy on Apr 21, 2015 10:04:42 GMT -5
I put my thumb on the spark plug hole, and when hitting the electric start, it was pushing my thumb with a good amount of pressure. So not sure where else to go with this.
I am picking up a 2005 Vento Zip R3I towards the end of the work week, and swapping my newish parts onto it. Pickin it up from a buddy for only $60.
boggin
Apr 21, 2015 10:10:58 GMT -5
Post by niz76 on Apr 21, 2015 10:10:58 GMT -5
Thinking hard to try to help... maybe it has a head gasket leak (or base gasket)? A proper compression test would tell u if it did. You could take the head off and see if it's showing any signs of a leak. Spark, fuel, and compression...
Sounds like u have spark now.. Fuel can be tricky but as long as the plug isn't soaked from flooding or simply not getting fuel, this should be easy enough to diagnose. Compression can be tricky without a gauge... With the soft seizes u were experiencing it may well have dropped your new cylinder and rings below the magic 90 to 100 psi mark...
boggin
Apr 21, 2015 10:29:49 GMT -5
via mobile
Post by thatcrazyguy on Apr 21, 2015 10:29:49 GMT -5
Cant find the link to making a home made tester -.- looked all in the tech section, and the search section.
boggin
Apr 21, 2015 12:10:28 GMT -5
via mobile
Post by thatcrazyguy on Apr 21, 2015 12:10:28 GMT -5
Went to HF and bought a compression test kit, 50psi. Way to low!!! Now time to find out whats causing it.
boggin
May 6, 2015 18:20:48 GMT -5
via mobile
Post by thatcrazyguy on May 6, 2015 18:20:48 GMT -5
Would a scoot fire up if the plug was fouled?
Post by niz76 on May 6, 2015 18:37:08 GMT -5
Sometimes it'll act like it wants to start but a fresh plug will bring it right to life. I'd guess with your setup a 80 or 85 mj. You can try snorkel in and out and see if it helps with each tune..
boggin
May 6, 2015 18:53:08 GMT -5
via mobile
Post by thatcrazyguy on May 6, 2015 18:53:08 GMT -5
Sometimes it'll act like it wants to start but a fresh plug will bring it right to life. I'd guess with your setup a 80 or 85 mj. You can try snorkel in and out and see if it helps with each tune.. The 85 was not enough, but ill try it without the snorkel and then an 80. Im gonna try and make it up to your house friday buddy
boggin
May 6, 2015 18:54:25 GMT -5
Post by niz76 on May 6, 2015 18:54:25 GMT -5
Sometimes it'll act like it wants to start but a fresh plug will bring it right to life. I'd guess with your setup a 80 or 85 mj. You can try snorkel in and out and see if it helps with each tune.. The 85 was not enough, but ill try it without the snorkel and then an 80. Im gonna try and make it up to your house friday buddy I'll be here! We'll get that baby screamin!
boggin
May 6, 2015 19:02:59 GMT -5
via mobile
Post by thatcrazyguy on May 6, 2015 19:02:59 GMT -5
The 85 was not enough, but ill try it without the snorkel and then an 80. Im gonna try and make it up to your house friday buddy I'll be here! We'll get that baby screamin! I believe with your help it will I try what I know, but I dont know everything!!! Ill give you a call when im close, should be about 1. Thats if I get it in running condition
boggin
May 6, 2015 19:07:09 GMT -5
via mobile
Post by thatcrazyguy on May 6, 2015 19:07:09 GMT -5
Just for verification, the snorkel is the tube where air flows into the airbox, right or wrong
boggin
May 6, 2015 21:20:50 GMT -5
Post by niz76 on May 6, 2015 21:20:50 GMT -5
Just for verification, the snorkel is the tube where air flows into the airbox, right or wrong correct
boggin
May 6, 2015 21:38:58 GMT -5
via mobile
Post by thatcrazyguy on May 6, 2015 21:38:58 GMT -5
Just for verification, the snorkel is the tube where air flows into the airbox, right or wrong correct Thank you my friend, ill mess with it in the morning, see if I cant get her running , then I have after work for about 2 hrs. Hoping to god I can get it running and make it up to "the nizinators" house haha
boggin
May 7, 2015 20:31:59 GMT -5
via mobile
Post by thatcrazyguy on May 7, 2015 20:31:59 GMT -5
Picked the scoot up last night with a friends truck, got it home, yesterday I realized it had no gas as well. Today I filled up a can before work, topped the tank off, and all the gas is gone already, all over its parking spot & its pouring out of the float bowl drain, I know that if I tighten the screw itll stop the leak, but why is it pumping gas without it even trying to be started? Bad fuel petcock?
boggin
May 8, 2015 8:16:42 GMT -5
Post by 90GTVert on May 8, 2015 8:16:42 GMT -5
Yeah, if you have a vacuum petcock it should not be allowing any additional fuel to the carb if the engine is not being cranked over.
