Post by jcataldo30 on Apr 19, 2015 14:13:32 GMT -5
I have a 93 jog and I was using it with my brand new battery and everything worked perfectly fine but while I was riding the battery fell out of the battery casing still connected to the terminals and touched my kick start and I saw a tiny spark but I stopped put the battery back in place and tapped it in and when I got home I noticed the battery was leaking acid so I took it out put it aside and called the company since it's under warranty , I received my new battery yesterday and when I had installed it nothing was working the bike still turns on with the kickstart and all of my lights and the horn work but everything is very dull like the battery is not even in the bike I tried charging the battery for hours and that did not help I put new terminals on the battery connectors and That did not do anything I also tried two more new batteries and nothing worked , the bike runs fine with no battery still works off kick start it just gets no connection to the battery does anyone know how to fix this
Post by niz76 on Apr 19, 2015 14:29:50 GMT -5
Did it blow the fuse?? It should be located right where the battery box is in a little white plastic tube.
Post by 'O'Verse on Apr 19, 2015 16:03:10 GMT -5
I just changed my fuse not to long ago. PDF manual says 7amp glass fuse. Local autoparts store only had 7.5a. Works fine. But on my bike if the fuse blows. Nothing works. Lights, dash, starter,etc. Have you tried sanding battery terminals. Light scratch on both battery and new terminals can't hurt.
