Post by joshua864 on May 9, 2015 20:56:56 GMT -5
Post by Elektrey on May 9, 2015 21:11:09 GMT -5
dont see anything
Post by joshua864 on May 9, 2015 21:33:49 GMT -5
Post by Elektrey on May 9, 2015 21:38:27 GMT -5
all that noise is coming from the clutch?
Post by joshua864 on May 9, 2015 21:45:23 GMT -5
all that noise is coming from the clutch? Nooo just that crackling popping sound when the clutch engages
Post by Elektrey on May 9, 2015 21:47:47 GMT -5
I only heard it once I think.
Have you taken the clutch off and inspected it?
Post by joshua864 on May 9, 2015 22:09:00 GMT -5
Just noticed it earlier but i had it off like 2 days ago with the whole vari deal and didn't notice anything
Post by Elektrey on May 9, 2015 22:10:50 GMT -5
something might have changed, can't hurt to take it off again and look at it.
Post by joshua864 on May 9, 2015 22:19:24 GMT -5
Wont be able to till Monday just trying to figure out what it could be till then. Clutch springs, shoe, ect...
Post by Elektrey on May 9, 2015 22:21:51 GMT -5
sounds like maybe one of the shoes has come out of pivot or the little rubber thing that holds it in has gone bad or something.
Post by iwiketuddlz on May 10, 2015 4:31:09 GMT -5
Hey flip flops
Post by joshua864 on May 10, 2015 12:58:22 GMT -5
Seems to be worse today not necessarily the noise but I can feel something dragging pretty bad and its got that "flat tire effect"
Post by Fox on May 10, 2015 15:54:56 GMT -5
Need to take it apart completely. Could be the grease has dried up inside so it's not opening smoothly like it should. If the slots in the torque driver are worn then just get a new one.
Could be the bearing(s) are failing so the bell isn't staying perpendicular to the clutch assy. Next time you have the clutch off grab the input shaft on the tranny and pull it up/down side/side to check that bearing in there for slop too.
Post by joshua864 on May 10, 2015 19:18:47 GMT -5
Hoping to have time to check it out after work tomorrow I'll take it completely apart and dbl check everything
Post by joshua864 on May 10, 2015 19:25:35 GMT -5
