HELP!
May 10, 2015 10:34:49 GMT -5
Post by burnleycasual1882 on May 10, 2015 10:34:49 GMT -5
I've recently purchased a Branson 49cc Cuba not even rode it yet as i haven't done my test however what's happening is i started it up the other day and decided to give it a run up and down the front street and all of a sudden when i had it in full throttle it decided to slow down and stall and will only move around 7mph when the throttle is twisted ever so slightly anything more than 1/4 revs and it'll slow and stall it's a pain in the arse. I'm not a petrol head so not very clued up on the subject any information will help,many thanks
Post by 90GTVert on May 10, 2015 11:39:45 GMT -5
Sounds like it could be a clogged main jet. Not sure if you bought it new or used, but if it's used or sat with fuel in it for a long period of time that would be more common. Could be simply running lean from improper jetting or if it is missing the airbox or any part of the airbox.
HELP!
May 10, 2015 12:17:58 GMT -5
Post by Elektrey on May 10, 2015 12:17:58 GMT -5
its also possible that part of your throttle cable has slipped out, allowing you to only go 1/4 throttle or so.
HELP!
May 11, 2015 13:44:16 GMT -5
Post by burnleycasual1882 on May 11, 2015 13:44:16 GMT -5
Sounds like it could be a clogged main jet. Not sure if you bought it new or used, but if it's used or sat with fuel in it for a long period of time that would be more common. Could be simply running lean from improper jetting or if it is missing the airbox or any part of the airbox. Used mate,however it's started running again all of a sudden and not got a clue why lol! Took it for a ride out the other day and only managed to get up to 10mph if that and decided to put some more petrol in today and it's working fine....going to take it for a spin when i get up for work in the morning and see how it goes.
HELP!
May 11, 2015 17:51:31 GMT -5
Post by scooterpimp on May 11, 2015 17:51:31 GMT -5
Bad or water in the gas?
HELP!
May 13, 2015 8:23:36 GMT -5
Post by burnleycasual1882 on May 13, 2015 8:23:36 GMT -5
Not got a clue what was up with it mate,it's starting to play up again now. When i kick start it i have to keep the throttle on full for it to even tick over.....it's pissing me off now,i'm not very mechanically minded lol !!
HELP!
May 13, 2015 9:42:58 GMT -5
Post by stevec on May 13, 2015 9:42:58 GMT -5
try adding some injector cleaner to the gas, not a lot though. make sure you are using at least 91 octane gas at all times.
