Post by hppowdercoating on May 11, 2015 7:23:04 GMT -5
Newest Project build.. Ruck clone main Frame. Modded Neck & Engine Mount. Neck,Tripple tree, 14" wheels/Tires & Engine from 2008 Theft Recovery Aprilia Sportcity 125cc scoot.. I still have to weld on a few brackets/Tabs before I break Down and powder coat.. [/img]
Post by 90GTVert on May 11, 2015 8:36:04 GMT -5
Very nice. I don't recall seeing one done with 14" wheels front and rear before.
Post by hppowdercoating on May 12, 2015 17:46:21 GMT -5
Very nice. I don't recall seeing one done with 14" wheels front and rear before. Thanks.. With about 10-hp and around 100-lbs lighter then original scoot it should run 65-70 mph...
Post by iwiketuddlz on May 18, 2015 5:01:18 GMT -5
Dang very nice but would be Alot nicer with a 2t.... Spaaat spaaaaadin ...power! I do like the 14* wheels
Post by FrankenMech on May 18, 2015 19:19:39 GMT -5
Interesting!
It looks like you got a stretch out of it also.
How did you get 14" wheels to fit on a long case 125cc?
What size tires are you running?
I am looking to cram a 125cc into my ruckus clone r-trike. Scoots are rare around where I live and pieces/parts to make things out of are even more rare.
Post by hppowdercoating on May 18, 2015 23:14:20 GMT -5
Interesting! It looks like you got a stretch out of it also. How did you get 14" wheels to fit on a long case 125cc? What size tires are you running? I am looking to cram a 125cc into my ruckus clone r-trike. Scoots are rare around where I live and pieces/parts to make things out of are even more rare. The engine is an Aprilia 125 , it came with the 14" wheels..
Post by FrankenMech on May 19, 2015 11:12:14 GMT -5
Good find! They must have an 'extra long' long case engine. At least some manufacturer has figured out that tiny wheels fall into potholes. St Louis has the same pothole making weather as KC does. Streets in KC suck.
Any tips on searching craigslist etc for junk scoots that don't come up with hundreds of mobility scooters? LOL
Post by hppowdercoating on May 27, 2015 10:49:01 GMT -5
Updated pic.. Blasted & Powder coated frame gloss black. Cut down & welded seat frame to main frame. Cut & modified plus ceramic coated stock Exhaust.. Working on custom under cowl.. Need to mount a headlight/ Taillight & blinkers, then finish Wiring everything..
Post by 90GTVert on May 27, 2015 12:03:15 GMT -5
Nice to see something different in a custom Ruckus/Chuckus!
Post by hppowdercoating on Jun 13, 2015 16:43:11 GMT -5
Got it running and riding, still need to wire headlights & get gas tank cover.. Runs and Rides great...
Post by katastroff on Jun 13, 2015 16:48:44 GMT -5
That's one awsome ruck!!!!
Post by iwiketuddlz on Jun 13, 2015 18:30:13 GMT -5
Mmmm? Does it have a fuel pump??
Post by hppowdercoating on Jun 13, 2015 19:35:48 GMT -5
Mmmm? Does it have a fuel pump?? Yep... Vacuum pump for 150cc scooter...
Post by iwiketuddlz on Jun 13, 2015 19:49:28 GMT -5
Well shoot learn sumtin ever day!!
Post by FrankenMech on Jun 14, 2015 9:18:25 GMT -5
Another Black beauty. Looks WAY better than mine!
I like the foot pegs and the muffler.
Mine isn't stretched, the engine sits farther forward.
Vacuum pumps look a lot like vacuum petcocks but there is a difference. My pump(s) ride right down on the left side between the tank and the valve cover. I have an electric unit to run in parallel with the vac unit to help it start after I run it out of gas. The vacuum pumps take forever to get a prime and pressurize the system.
I think one can get a piece of tread plate for the gas tank cover. I have also seen expanded metal units. I am still using my OEM plastic but split in half so it comes off and on easy. My fuel tank rides on studs that I cap with acorn nuts.
