Post by rollands on May 18, 2015 14:10:32 GMT -5
Im trying to temporary make this badly drawn circuit: Battery>--Switch>--Starter motor But i dont know what kind of switch i can put there, im guessing 20Amp would work?
Post by humanshield on May 18, 2015 14:28:19 GMT -5
You do not want to use a relay?
You'll need a pretty heavy duty switch to do that. More than 20 amps.
Post by rollands on May 18, 2015 14:38:48 GMT -5
my old relay died and i wont get a new one for probably 2 to 3 weeks so i decided to just wire it straight, i could just put the wire on the terminal, but that will get annoying fast, switch would do the trick, but i dont know how many amp switch do i need. Maybe someone has experience with doing something like this?
Post by niz76 on May 18, 2015 14:48:40 GMT -5
I once bought a scoot where the owner had wired a starter button-the one from the handlebars- onto each side of the solenoid. It worked fine..
