Post by Elektrey on May 22, 2015 15:00:38 GMT -5
They are made of cheap weak pot steel. The threads are super fine, threads are super shallow... There's a reason to toss the stock nut for a better one from the hardware store. I just replaced my stock one when I first took my clutch nut off s year or so ago. I had to toss it I couldn't bring my self to reuse the super thin super flimsy nut. The one I used to replace it is just slightly thicker, but you can tell by touching them better steel. I ain't sayin replace it everytime, I just said that I figured the cheaply made nuts were meant to be changed. If ( super slim chance, like maybe half of one percent ) that fuc*: comes loose while your riding... nah, I was referring to the variator nut that Fox posted. my vari nut is like a whole inch thick and very well machined. the clutch nut on the otherhand I could see needing replacement
Post by scooterpimp on May 22, 2015 16:19:36 GMT -5
I can see where replacing them may be a good idea , being there arent alot of threads on that narrow nut , easily stressed..
