Post by Silar on May 21, 2015 10:18:14 GMT -5
On my wife's scooter, a Vino Classic 50 4t, when she uses her turn signals, it makes almost link a dinging chime sound to let you know that you have your turn signals on so you know to turn it back off.
On my scooter, there is no sound. During the daytime, the dash lights aren't bright enough to even see if they are on, and my turn signals are under each side of the handlebar pastics so I can't visually see them either.
Is there an addon thing I can put in line with the turn signal relay or switch that will make some kind of clicking, dinging, chiming noise so I remember to turn them off?
I apologize ahead of time for all the extreme engineering technical terminology I used in this post! lol
Post by birdman on May 21, 2015 10:26:24 GMT -5
its called a flasher. Put a more noisy one in lol
Post by Fox on May 21, 2015 10:30:33 GMT -5
Post by Silar on May 21, 2015 10:44:17 GMT -5
its called a flasher. Put a more noisy one in lol Anything would be more noisy than no noise at all!
Post by Silar on May 21, 2015 10:45:34 GMT -5
It'd be nice to know for sure.
Post by birdman on May 21, 2015 10:50:52 GMT -5
You could even get on from a car that makes a noise that you like.
Post by 90GTVert on May 21, 2015 11:19:47 GMT -5
Some scoots have the standard 2 prong that's common in cars. If you have those you can go right to a local auto parts store and find a loud flasher most likely. One of my flashers ticks but I still can't hear it unless I'm at idle so if you can find one claiming to be loud go for that.
Post by niz76 on May 21, 2015 11:39:24 GMT -5
I had this blinker relay just sitting around so I don't know where it came from... When searching for one, it should say something about "audible signal". It's at around the 40 second mark in this vid:
Post by Fox on May 21, 2015 12:06:14 GMT -5
This guy has a genuine Buddy and at about 40 seconds in he turns the blinker on and it sounds pretty loud. Clicking sound. Then at 1:30, he removes the relay and it sure does look a lot like the one I linked you too. Scooter dynasty sells a relay for Genuine Buddy. I just called and the mechanic says they click. I know they have a bad rep for slow shipping so if you want I can pick one up in person and ship it to you. He will probably knock off $5-$10 for me. www.scooterdynasty.com/flasherrelayassemblyfor125cc-150ccgenuinebuddyblur.aspx
Post by Silar on May 21, 2015 12:32:20 GMT -5
This guy has a genuine Buddy and at about 40 seconds in he turns the blinker on and it sounds pretty loud. Clicking sound. Then at 1:30, he removes the relay and it sure does look a lot like the one I linked you too. Scooter dynasty sells a relay for Genuine Buddy. I just called and the mechanic says they click. I know they have a bad rep for slow shipping so if you want I can pick one up in person and ship it to you. He will probably knock off $5-$10 for me. www.scooterdynasty.com/flasherrelayassemblyfor125cc-150ccgenuinebuddyblur.aspxThat's exactly what I'm looking for! Lemme see if I can source one myself, but if I can't I may take you up on that! Is it 3 wire?
Post by Fox on May 21, 2015 12:38:21 GMT -5
Yeah. Three prong. The guy in the video even says "And then you've got a three prong connector"
I see that that ebay dealer has 0 units available so lemme know and I will pick one up from Vince at Scooter Dyanasty and then we can work out the payment details via private messaging.
Post by scooterpimp on May 21, 2015 17:27:22 GMT -5
The flasher in my keeway makes a noticeable clicking when on , put loud one on ruck clone ( automotive type) most china scoots have a3 wire plug on a pigtail , but only uses 2 of the wires , cut pigtail from china relay/flasher , add 2 speaker female spade connectors & bingo.. 552 flashers are very cheap @ auto parts stores.
Post by themajekalbum on May 23, 2015 14:13:03 GMT -5
I have the Orange 3 prong naraku led flasher on my kymco and they used a very loud clicker in it! Can easily hear it over 9500rpm
Post by Silar on May 23, 2015 21:12:39 GMT -5
Will that work with regular bulbs too?
