Post by scooternub on Jun 10, 2015 8:28:23 GMT -5
so should i have that ring gasket though?
Post by 90GTVert on Jun 11, 2015 8:02:09 GMT -5
You only need 1 gasket for the exhaust. Either a ring or flat gasket. I've always used the ring gaskets with these engines since there's a receiver in the exhaust port for it. I suppose you could use both, the a ring style gasket should be able to do the job.
Post by scooternub on Jun 11, 2015 9:27:45 GMT -5
You only need 1 gasket for the exhaust. Either a ring or flat gasket. I've always used the ring gaskets with these engines since there's a receiver in the exhaust port for it. I suppose you could use both, the a ring style gasket should be able to do the job. Awesome, I am glad I ordered a set of 5 ring gaskets yesterday, as just how you explained it and also my crush gasket will be here today. Like you said it, I wasn't sure if I needed one or both or, one or the other. Everything is piecing together. I'm in no rush, as that farmer guy/motorcycle mechanic is retiring in 2 weeks, I think he said he can help me then. Thank you for your input!
