Post by renagade281 on Jun 29, 2015 12:23:37 GMT -5
Replaced sparkplug with ngk c7hsa and it started but this is at full throttle... youtu.be/7PEhqKgxpsk
Post by Availien on Jun 29, 2015 12:27:26 GMT -5
You might need to check your valve clearance. Make sure the valves aren't touching the piston. Sounds kinda loud.
Post by renagade281 on Jun 29, 2015 13:06:49 GMT -5
Holy sh%& I just checked the valves and the one on the bottom with the e next to it was all the way loose. I could stick my whole pinkie in where the .004 feeler gauge should barely fit. I guess I didn't tighten it all the way yesterday. Or maybe going down a hill too fast caused it?
Post by Fox on Jun 29, 2015 13:19:48 GMT -5
Post by Availien on Jun 29, 2015 14:21:39 GMT -5
Is it running good now? Make sure nothing was damaged. Is the lock nut still there? The last thing you want to do is start that engine with a nut floating around somewhere in the crank-case. THEN you would have a major issue.
Post by Availien on Jun 29, 2015 14:28:10 GMT -5
It might help to print a checklist when doing maintenance. This way you make sure don't miss anything. I have done a checklist ever since I installed a BBK on a cool sport and forgot to tighten the same nut. The nut came off and went down in the crank case. I had to pull the entire engine apart to get that nut. My guide for the timing chain was chewed up and the chain broke. Not a fun fix, especially since it was MY fault. I almost did the same thing with my current bike because I failed to use my checklist. "I got this" is probably not a good mind-set when disassembling an engine. I learned that the hard way. lol.
Post by renagade281 on Jun 29, 2015 14:28:13 GMT -5
Yes it is running good now. It idles up and down.. Never did that before but as long as it runs I'm OK. Gonna buy another scooter next month and sell this one
Post by katastroff on Jun 29, 2015 16:55:46 GMT -5
New scooter, new problems. I would keep this one since you practically got all of the bugs out.
Just my 2cents.
Post by Availien on Jun 29, 2015 17:19:07 GMT -5
I'm with Katastroph on this. Probably better off keeping it and using the money you intend to buy a new one with to fix this one up real nice. It's your decision though.
Post by renagade281 on Jun 30, 2015 12:37:07 GMT -5
It seems as if my mixture screw on the side of the carb isn't doing anything no matter how many times or which way I turn it. Scooter is running fine at high speed but idle and low speed is kinda sluggish. I tried following the PDI video but the mixture screw isn't effecting how it idles
Post by Availien on Jun 30, 2015 12:56:04 GMT -5
Did you try starting the bike and then tightening the screw all the way in? That should cut the bike off. You might have a problem with the carburetor if that doesn't do anything.
Post by Availien on Jun 30, 2015 13:10:07 GMT -5
It seems as if my mixture screw on the side of the carb isn't doing anything no matter how many times or which way I turn it. Scooter is running fine at high speed but idle and low speed is kinda sluggish. I tried following the PDI video but the mixture screw isn't effecting how it idles Low speed problems are probably related to the needle position.
Post by renagade281 on Jun 30, 2015 23:45:58 GMT -5
Yea it doesn't do anything if I tighten it All the way
Post by Elektrey on Jul 1, 2015 1:09:55 GMT -5
possible leaks? dirty idle jet?
Post by katastroff on Jul 1, 2015 5:03:37 GMT -5
Time to buy a can of carb cleaner me think.
