Post by derbiman on Aug 2, 2015 14:12:07 GMT -5
Jump start it. It won't hurt it. Done it a lot.
Post by Jwhood on Aug 2, 2015 15:45:57 GMT -5
Off a car?OK put an old battery in hooked up jumper cables and still doesn't want to start,well it almost starts but just won't turn all the way over even with starter fluid?I figured that would happen didn't have it running just had cables hooked to truck battery,also seen something that's not normal just now seen smoke coming out of shroud screw holes so now I'm thinking the oil seals are shot and that would give me a no start issue I'll have too dig into it tomorrow,can't believe a scoot with a little over 1300 miles could have blown oil seals already?
Post by scooterpimp on Aug 2, 2015 16:28:22 GMT -5
Not recomended, but If jumped from a car , dont have the car running. , or poof! Instant scooter McNugget! Just my 2 cents.
Post by Jwhood on Aug 5, 2015 18:46:33 GMT -5
Maybe a loose ground wire,the kill switch button is gone I have to use a screw driver to slide it from left to right
Post by scooterpimp on Aug 8, 2015 13:12:36 GMT -5
Crank seals can go bad from sitting for extended periods (shrink/rot) not sure on minarellis , but old vespas/lambrettas & vintage dirtbikes they shrink & suck air. Or suck in gear oil depending what side was bad.
Post by Jwhood on Aug 10, 2015 0:35:52 GMT -5
Re cleaned carb pulled out intake re sealed it with some rtv,still no go,one thing I noticed was the spark is faint when I hold it against metal,I'm wondering if its the coil or if the rectifier is going bad
Post by 90GTVert on Aug 10, 2015 8:32:57 GMT -5
Check the spark with a wide gap... like cut the ground strap off of an old plug or use an HEI tester or adjustable gap tester. Sometimes they fire the little gap and look alright, but they won't or won't consistently jump a larger gap. If it will jump the big gap consistently then spark should be alright. If not start checking pickup and exciter coil output. www.youtube.com/watch?v=q9-mr7BXIho
Post by frank50e on Aug 11, 2015 13:25:09 GMT -5
What is the compression on this motor?If you don't know thus begins the consequent tail chasing that goes on and on.
Post by Jwhood on Aug 11, 2015 21:10:07 GMT -5
Did not check yet I'm thinking oil seal is bad might just hold off and do the 45 mm crank and 54 mm cylinder in future,need to start focusing on the l.c tgb build I started but quit cause I was getting frustrated with the stator not working!!
Post by scooterpimp on Aug 12, 2015 5:56:07 GMT -5
Sometimes ya just got to walk away from it for a while.
Post by Jwhood on Sept 27, 2015 18:14:44 GMT -5
Bought some oil seals for the yamati rx8, hopefully should be here mid week so I can get this scooter up and running
ceeja
Post by ceeja on Sept 27, 2015 19:19:29 GMT -5
i jump mine straight on the starter. red to the wire that goes to teh starter, just pull it off and touch it there, and ground right on the starter body. thats the best ground for the motor.
Post by Jwhood on Oct 1, 2015 20:38:24 GMT -5
Seals came today,gonna use my day off to slap them in and see if that why she won't start
Post by Jwhood on Oct 4, 2015 15:17:05 GMT -5
So the place sent me wrong seal for stator side so now I have to order a new one,when I took off stator old seal was super loose and hanging 1/2 way out
Post by iwiketuddlz on Oct 4, 2015 16:53:55 GMT -5
Darn that sux Hope ya get her running bro!!
