Post by scott7 on Jul 24, 2015 14:56:41 GMT -5
Hey guys need help, scooter bogs down, no top end unless I unhook air breather at carb. Then it runs good. I changed carb and it has same problem. I put on new air breather and it has same problem. But if I take off air breather at carb it runs good. I'm at a loss on this one
Post by thatcrazyguy on Jul 24, 2015 15:20:49 GMT -5
Try changing the jets in the carb?
Did you make any changes for this to occur
Post by niz76 on Jul 24, 2015 15:22:22 GMT -5
When you remove the "air breather" you are leaning up the air/fuel mix. Sounds like you're running rich and need to downjet.
Post by scott7 on Jul 24, 2015 15:25:59 GMT -5
Bought this scooter with this problem. Was a no tamper carb,drilled heads of screws to get bowl off so it must be stock jet, that's when I took brand new carb off another scooter I have and put it on there . Got same problem
Post by thatcrazyguy on Jul 24, 2015 15:27:33 GMT -5
Bought this scooter with this problem. Was a no tamper carb,drilled heads of screws to get bowl off so it must be stock jet, that's when I took brand new carb off another scooter I have and put it on there . Got same problem Try downjetting the carb as niz76 stated above!!!
Post by niz76 on Jul 24, 2015 15:30:26 GMT -5
Yes, the other carb probably has a different sized jet in it...
Post by scott7 on Jul 24, 2015 15:31:31 GMT -5
I was thinking of putting different air breather with less restriction, what do you guys think?
Post by scott7 on Jul 24, 2015 15:43:19 GMT -5
I'll have to pull carb back off and see what jet is in it, then order some smaller ones, but I already got an high volume air filter coming in, that's why I'm asking
Post by 90GTVert on Jul 24, 2015 15:50:01 GMT -5
to the forum! I think kinda the same as the fellas above... jetting would be a better idea. You may get really lucky and have the air/fuel mixture end up right just by swapping from filter to filter, but you really should tune with jets and adjustments rather than trying to tune with air filters. www.youtube.com/watch?v=K5j8gHg5kMc
Post by Fox on Jul 24, 2015 18:18:41 GMT -5
Yep. ^^^ There's no law that says a cone style filter can't be used. You just have to make sure it's not too lean after installation by doing plug reads and playing with different jets as needed til the spark plug is brownish. If you run lean then you'll burn valves and/or put a hole in the piston. Lean:
Post by usmcdoc on Jul 24, 2015 20:01:23 GMT -5
Yep. ^^^ There's no law that says a cone style filter can't be used. You just have to make sure it's not too lean after installation by doing plug reads and playing with different jets as needed til the spark plug is brownish. If you run lean then you'll burn valves and/or put a hole in the piston. Lean: WOW!! Now THAT was a super lean run engine..
Post by scott7 on Jul 24, 2015 22:09:24 GMT -5
Ok thanks ,I'll try jetting down and let you guys know how it goes. May take a little while cause ill have to order them.
Post by Fox on Jul 25, 2015 6:30:54 GMT -5
Maybe you can get away with opening up the stock air filter box some. In the end you are looking for a brownish plug so experiment and see if you can find a balance with what you already have. The best part is that it's only gonna cost you $0.00 dollars. There's a plug or bung in the end of the snorkel that can be removed. There's a small tube inside the cover that can be removed to open up more flow. You can even drill holes in the cover to allow for more air flow.
Post by scott7 on Jul 25, 2015 9:01:07 GMT -5
Ok guys, thanks for your info, I just got back from taking all restrictions out from stock air cleaner, no change. I didn't drill holes in air cleaner though. I took off carb and checked accelerator pump diagram , it looks good and didn't see any cracks. I pulled out main jet and its a number 78. Put all back together and ran down road, still bogs down bad. Unhooked from carb again and runs good, went about 2 mobiles pulled plug out. Looks kinda slightly white on the top prong, if that's what it's called , base looked brown and white. Can it even be possible the main jet with it being a 78, or is there something else going on here
Post by scott7 on Jul 25, 2015 9:18:16 GMT -5
Guy I bought this from did say he use to get 120 mpg, I didn't believe it though. Maybe he replaced the carb and had the same problem then sold it to me lol, we'll I guess all I can do is start changing jets , what should I start with next size down
