Post by TurboTyler on Jul 28, 2015 23:47:49 GMT -5
If the valve stem is bent you would hear some kind of ticking unless your valves are adjusted too lose.
Post by Mrx2002 on Jul 28, 2015 23:55:18 GMT -5
Looks like a bent valve. Eazy way to tell if its bent adjust the valve lash so the valve gets pushed in as far a possible. Now with your hand on the fan turn the engine over untill the valve is at its lowest position. Now turn the engine backwards if the valve doesn't stick its very likely its not bent. Remember DO NOT use the starter or kick start with the valve lash adjusted all the way hand only! Good luck man.
