Post by Jyrsky on Aug 19, 2015 7:55:30 GMT -5
As you can see from the pictures one of the clips came off while riding. Something (probably the clip, but how?) has eaten the clip recess much bigger than it's supposed to be Could this have something to do with the small end bearing being worn out or the wrist pin? Could the clip just snap on its own? Any ideas on what could have caused this would be appreciated The second image is what the recess should look like The last image has a little piece of the clip embedded into my cylinder
Post by derbiman on Aug 19, 2015 8:14:03 GMT -5
The clip will come off if installed wrong. The opening of the clip should be installed at either the 6 o'clock or 12 o'clock position. If they are in the 3o'clock or 9 o'clock position, the force of the piston going up and down may dislodge the circlip.
Post by Jyrsky on Aug 19, 2015 9:14:00 GMT -5
I can't remember which way it way they were because I opened/reassembled upper half +2000km ago. They were that ''Double G'' type if that makes any sense Im just afraid that if it wasnt the clip itself, my new malossi cylinder kit might do this too
Post by katastroff on Aug 19, 2015 9:20:41 GMT -5
The clip will come off if installed wrong. The opening of the clip should be installed at either the 6 o'clock or 12 o'clock position. If they are in the 3o'clock or 9 o'clock position, the force of the piston going up and down may dislodge the circlip. There are specific times of the day to install clips?
Post by tsimi on Aug 19, 2015 9:23:22 GMT -5
Post by derbiman on Aug 19, 2015 10:01:42 GMT -5
Position, not time.
Post by derbiman on Aug 19, 2015 10:03:23 GMT -5
Just remember,It's 5 o'clock somewhere!!!
Post by iwiketuddlz on Aug 19, 2015 11:18:44 GMT -5
Mywhahaa.i love it
Post by Fox on Aug 19, 2015 13:17:11 GMT -5
Sorry for your loss. I hate that a little 62¢ part can ruin an entire top end.
I always install them with the open part facing the crank (6 o'clock) so the clip will want to expand in the groove on the power stroke but I have had them come out that way so not sure if it really matters.
I have read post from guys saying they put Loctite on the clips after they are installed. Never did it myself but I assume they used brake cleaner, carb cleaner or starting fluid to clean the piston/clip of any oils so the Loctite will stick well. I can't remember if it was the red or blue they recommended.
The one and only rule I have is that you can't bend the clips and then bend them back and expect them to hold. Once they are bent they are toast
Post by iwiketuddlz on Aug 19, 2015 13:27:54 GMT -5
Darn I bend them and reuse the all the time!!! Always have and never had one come out!!! Fingers crossed huh, my engine turn very high rpm as well upwards of 15k at times!!! I also just put them in no certain way or nutin,,, I will start though!!!thanks for the tip!!!!
Post by Fox on Aug 19, 2015 13:47:03 GMT -5
Post by derbiman on Aug 19, 2015 13:58:55 GMT -5
You guys thought I was crazy!!! Thanks for the backup, Fox. And yes folks,there is a certain time of day to install circlips. Beer- thirty!!! Lol
Post by Jyrsky on Aug 19, 2015 16:00:37 GMT -5
But why is that clip recess ''gouged'' out like that? Just asking to be extra sure I wont ruin that new kit
Post by derbiman on Aug 19, 2015 16:37:50 GMT -5
Caused by inertia. Look it up. The clip may not have been tight enough.
Post by stuckchuck on Aug 19, 2015 16:59:27 GMT -5
i lost one on a 10 mm kit after 7000 miles
