Post by sobotek on Aug 24, 2015 15:38:38 GMT -5
hello folks.. i have been working on this problem for a longtime ( 3 or 4 months at least).. the problem i am having are the gears in the transmission..i made a video so you can see what i mean. www.youtube.com/watch?v=yxsPvpzeJdcso now you can see/hear that something is not ok.. i changed all the gears.. and all bearings and oil seals two times.. so that i eliminated the problem with maybe a new faulty bearing.. i changed the clutch wrist pin bearing and cvt cover bearing.. i putt in the 85-90oil it was the same i put in regular 10-40 oil the same.. everything i have done its the same.. all three gears are new in the engine and the old gears are looking fine.. i would post a picture butt somehow i cant.. guys please help me im stuck.. i just dont know what to do anymore..
Post by Fox on Aug 24, 2015 16:03:02 GMT -5
Post by iwiketuddlz on Aug 24, 2015 17:31:29 GMT -5
I'd say drive it and I bet it will quiten down!! Mine where loud like that when i first Installed them as well.....
Post by katastroff on Aug 24, 2015 17:38:18 GMT -5
Are these stock or aftermarket gears?
Some aftermarket gears are noisy, some (I think its the Malossi gears) make a turbo like sound when you take off.
Post by spaz12 on Aug 24, 2015 17:46:03 GMT -5
Was it making noise before you put gears in it? If so, I'm wondering if there isn't a problem with the case or the gear cover?
Post by 'O'Verse on Aug 24, 2015 18:49:17 GMT -5
It definetly sounds like gears. Have you check to see if your rim is rubbing against the case at all.
Post by scooterpimp on Aug 24, 2015 20:11:31 GMT -5
Any oil in that gearbox? Kinda sounds like the old pencil sharpeners in school.
Post by sobotek on Aug 25, 2015 3:03:56 GMT -5
They are new oem stock gears.. I have changed the whole cvt cover aswell.. I put in 105cc 85-90 oil in it.. And yes it was making the same noise before i putt in these new gears.. I checked the rim and it doesnt grind with the cover.. The gears are making a turbo like sound when i take off.. Then they quiet down a little but you can still hear them.. Anymore suggestions? Please.. I cant even sell this thing in this working condition.. Acutaly i dont want to sell it because of my endless working hours i putt in it...
Post by katastroff on Aug 25, 2015 5:28:03 GMT -5
The grooves in the gears are they parallel to the shaft or they have a bit of an angle? Gears with straight groove will do a turbo sound.
Post by sobotek on Aug 25, 2015 7:01:26 GMT -5
these are the old ones
Post by katastroff on Aug 25, 2015 12:11:39 GMT -5
How does it run?
Does it only do the "turbo" sound?
Post by sobotek on Aug 25, 2015 12:26:35 GMT -5
I think so. But you can still hear them at any speed.. At around 25-30kmh it does that loud turbo sound.. today i made 40kilometers because i thought gears will need some breaking in.. Butt its the same or worse i dont know if that is just my mind playing tricks on me.. Is there a possibility that the whole case is ruined.. My clutch shaft has a little play i dont know how or why.. Bearing has no play whatsoever on the cvt cover neither in the case..
Post by sobotek on Aug 25, 2015 12:30:26 GMT -5
The clutch shaft has about 1-2mm play at the end.. So did the old shaft.. Im exausted.. At least there are no more strange vibrations when i ride.. Before with the old gears there was sometime a atrange wobling vibration.. Butt at least thats gone i think..
Post by iwiketuddlz on Aug 25, 2015 13:28:07 GMT -5
Does the shaft fit tight in the cvt bearing?8mm ID bearing I believe ? Do you have metal in your oil when you drained it?? Do you have metal now??
Post by sobotek on Aug 25, 2015 13:31:47 GMT -5
Yes the shaft goes wery hard in the cvt cover bearing.. I help getting it in with rotating the tyre.. No no metal particles were in the oil.. Today after my trip i didnt changed the oil.. Should i?..
